Wipers
Page 1 of 4 1234 LastLast
Results 1 to 15 of 49
Like Tree5Likes
Cadillac STS Forum - 2005 through 2012 Discussion, Wipers in Past Cadillac Vehicle Discussion; Hi everybody.....new Caddy owner as of yesterday, well new to me. 2007 STS. I tried the search but nothing came ...
    kywildcat is offline Cadillac Owners Member
    Automobile(s): 2007 STS
    Jul 2014
    16
    Wipers
    Hi everybody.....new Caddy owner as of yesterday, well new to me. 2007 STS. I tried the search but nothing came up about rain sensing wipers. Do all STS's come with them or not. I was told mine had them, but I don't know how to use them yet. Any suggestions.......Thank you!
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,063
    Move the wiper stalk up one notch from its lowest position.
    dkozloski likes this.
    Neutrocuted's Avatar
    Neutrocuted is offline Cadillac Owners Fanatic
    May 2010
    467
    Re: Wipers
    The positions on the stalk that look like positions of a delay wipe are actually the rain sense sensitivity settings. The first click is low sensitivity and if you feel it is not wiping frequently enough for your taste or the current conditions raise it up a click or 2.
    Guy.Seminerio likes this.
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Quote Originally Posted by kywildcat
    Read the manual.
    Not all STS had them. No 2010-11 had them.
    Neutrocuted likes this.
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: Wipers
    You have to have a sensor stuck to the windshield glass on the passenger side of the mirror & RPO CE1.
    KRSTS Guest
    Re: Wipers
    I believe GM discontinued them in 2010 because idiots kept going thru car washes with them activated, destroying the wipers.
    Jul 2014
    16
    Re: Wipers
    Quote Originally Posted by 1BadCadSTS View Post
    Read the manual.
    You don't think I read the manual? It just said........"if Equipped"! Thanks for your support though!
    Thanks for all the other answers........I understand now!!!!
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Re: Wipers
    If you look in the manual it describes the system and the fact theres a sensor on your windshield... no sensor no rain sense... Seems to be common sense... Even for those who lack sense...
    Must not of looked too hard or read too good huh?...
    Rainsense™ II Wipers
    If your vehicle has this feature, the moisture sensor is
    mounted on the interior side of the windshield behind the
    rearview mirror.
    It is used to automatically operate the
    wipers by monitoring the amount of moisture build-up on
    the windshield. Wipes occur as needed to clear the
    windshield depending on driving conditions and
    the sensitivity setting. In light rain or snow, fewer wipes
    will occur. In heavy rain or snow, wipes will occur
    more frequently. The Rainsense™ wipers operate in a
    delay mode as well as a continuous low or high
    speed as needed. If the system is left on for long periods
    of time, occasional wipes may occur without any
    moisture on the windshield. This is normal and indicates
    that the Rainsense™ system is activated.
    To activate the Rainsense™ system, turn the wiper
    band to delay mode and select one of the four sensitivity
    levels indicated on the wiper stalk. The position
    closest to off is the lowest sensitivity setting, level one.
    This allows more rain or snow to collect on the
    windshield between wipes. Turning the wiper band away
    from you to higher sensitivity levels increases the
    sensitivity of the system and frequency of wipes. The
    highest sensitivity setting, level four is closest to low. A
    single wipe will occur each time you turn the wiper
    stalk to a higher sensitivity level to indicate that
    the sensitivity level has been increased.
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    Re: Wipers
    Quote Originally Posted by KRSTS View Post
    It was an issue between GM and the supplier. They're back on Cadillacs again.
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Quote Originally Posted by Guy.Seminerio
    100% correct
    KRSTS Guest
    Re: Wipers
    One of my favorite features
    John Wicz's Avatar
    John Wicz is offline Cadillac Owners Fanatic
    Automobile(s): 2009 STS AWD, 3.6L
    Feb 2007
    Chicagoland Area
    284
    Re: Wipers
    Mine too, I just wish that the HID's didn't have to be on all the time, I wish they could have done a dimmed high-beam on w/ the RainSense............
    Feb 2013
    Whitestone, NY
    28
    3,211
    Re: Wipers
    I agree with this. I don't leave it on because it leaves the HIDs on constantly. The HIDs deteriorate over time so it stays off. They should've set it up to where the headlights only come on when rain is sensed.
    KRSTS likes this.
  16. #14
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,063
    Re: Wipers
    The headlights are on when RainSense is active because it is law in most states that the headlights be on when precipitation is present. I do like the idea of only having the headlights on when moisture is actually being sensed by the system though, that would be very nice.
  17. #15
    John Wicz's Avatar
    Feb 2007
    Chicagoland Area
    284
    Re: Wipers
    Yes exactly, I agree 100% to what Guy and Curtc said!
  18. Remove Advertisements
