Exhaust rattle noise
Results 1 to 5 of 5
Like Tree2Likes
  • 1 Post By Ludacrisvp
  • 1 Post By CadiTamer
Cadillac STS Forum - 2005 through 2012 Discussion, Exhaust rattle noise in Past Cadillac Vehicle Discussion; Hi guys! I have anoying rattle noise comming somewhere from the exhaust. It's metalic sound like some balls inside. And ...
    Wojciech is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac STS 3.6 DI 2009 RHD with Performance Pkg
    Feb 2014
    Southampton, UK
    166
    Hi guys!
    And it's only between 1.500 - 2.500 RPM and it's very noissy when accelerating.
    I slide under car and can't see any loosenes.
    Anyone had similar issue?
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,499
    Re: Exhaust rattle noise
    I had the exact same issue. Was broken heat shield on the passenger side pipe (LHD model) ... Dealer found a TSB on it and used a hose clamp to fix it.
    Basically the shield cracked near the weld and would vibrate under certain engine load.
    See this thread for a photo of the hose clamp on the exhaust after I pulled it out to put in GMPP exhaust instead.
    http://www.cadillacforums.com/forums...installed.html
    Wojciech likes this.
    CadiTamer is offline Cadillac Owners Fanatic
    Automobile(s): 2006 STS 3.6 RWD
    Dec 2013
    22
    117
    Oh. Cool. I'm not the only one! I figured it was something in the resonator, but this seems much nicer... Hose clamp is a really cool thought. I think i'll do that now!
    Feb 2014
    Southampton, UK
    166
    Quote Originally Posted by Ludacrisvp View Post
    THANK YOU!
    Hope this will be the issue
    Feb 2014
    Southampton, UK
    166
    Fixed!!
    As CadiTimer said.
    Problem was heat cover.
    I welded it and problem gone
  8. Remove Advertisements
