Park light bulb
Results 1 to 15 of 15
Like Tree4Likes
  • 1 Post By PontiacV8
  • 3 Post By curtc
Cadillac STS Forum - 2005 through 2012 Discussion, Park light bulb in Past Cadillac Vehicle Discussion; Hi Guys! Where you have park light bulb? AllData says is in the same place as turning signal, which is ...
    Wojciech is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac STS 3.6 DI 2009 RHD with Performance Pkg
    Feb 2014
    Southampton, UK
    166
    Park light bulb
    Hi Guys!
    AllData says is in the same place as turning signal, which is easy to replace.
    I have RHD (UK, european) model end park bulbs are in the headlights.
    As I know there is only one possibilitie to replace the bulb...remove bumper and headlight.
    Do I relay have to do it in this way for parking bulbs as well? It will happen 2-3 times a year ...
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: Park light bulb
    We've never had to do ours, but it's reputed to be just the bumper cover; not as bad as it looks. The headlights stay in place.
    Feb 2014
    Southampton, UK
    166
    Re: Park light bulb
    Yeah, that's why I'm asking. In my case I have to take out headlights. I didn't find any clue to change that bulbs.
    PontiacV8's Avatar
    PontiacV8 is offline Cadillac Owners Fanatic
    Automobile(s): 2015 Camaro 2SS, Sold: 2006 STS (EXP) 1997 Seville STS (EXP)
    Dec 2006
    Germany / Nordhorn
    423
    Re: Park light bulb
    Quote Originally Posted by Wojciech View Post
    ...yes...I just changed the little parking light/position light/city light/peanut light-bulbs myself...
    ...the bumper cover has to be removed...and than loosen (and remove) the headlamps...
    ...there was no way to change the bulbs without headlamp loosening or removal...headlampwaschers, the rh (export) auto leveling module on the side door, connectors, the extra/additional wiring and whatever made it impossible to reach (and grab) the bulbs through the little headlamps "side doors"...opening the side doors without headlamp removal was also almost impossible...
    ...but the bumper cover removal was fairly easy...
    ...this is the export headlamp...with the additional autoleveling module on the side door... (on the picture the back door is loosen)
    ...to reach...and change the little bulb the side cover has to be removed...(the bulb is placed behind the W5W lettering)
    Wojciech likes this.
    Feb 2014
    Southampton, UK
    166
    Re: Park light bulb
    Thanks!
    Yes bumper removing is easy to do.
    But the bloody bulb... I couldn't get it by my fingers....
    I'm just interesting interesting. You said export model has extra auto leveling. What's does it mean? US doesn't have it? What the different is?
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,496
    Re: Park light bulb
    Export lamps have a little motor and that black module attached to the housing that continue to adjust the angle of the lights based on how level the car is. You go down a steep hill and it adjusts your lights so the low beam is higher. You go up a steep hill and it goes down as to not blind oncoming traffic. If you are pulling a heavy load that the suspension cannot compensate for it lowers the beams.
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,033
    Re: Park light bulb
    It means the headlights level themselves with grade differences...Say you're coming over a hill, the headlights will lower instead of shining into the night sky...Original U.S. registered STS's don't have this feature but exports do as I believe it is mandated by the European Government.
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,496
    Park light bulb
    Some domestic cars have it but it's not common (there are no STS cars with it that aren't export). I've driven one of the first year Chrysler 300C and it had auto leveling HIDs.
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,033
    Re: Park light bulb
    Quote Originally Posted by Ludacrisvp View Post
    I edited my post for clarity!
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    Re: Park light bulb
    With it adjusting the beam based on the angle of the car, it also compensates for squat (nose pointing up in acceleration) and dive (nose pointing down during braking.)
    It points down during squat to prevent blinding of drivers ahead and points up during dive to keep the road ahead well lit.
    Feb 2014
    Southampton, UK
    166
    Re: Park light bulb
    OK guys thanks
    I though that auto leveling for HID is also required in USA.
    So cars with HID but not auto leveling are verry anoying at night for oncoming traffic Isn't it?
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,033
    Re: Park light bulb
    OK guys thanks
    Not nearly as annoying as all of the reflector (non-projector) equipped cars/trucks driving around with HID conversion kits in them...
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: Park light bulb
    All US STS have load-leveling systems which mitigate this concern.
  16. #14
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,496
    Re: Park light bulb
    But the load leveling won't adjust for diving and squatting. As it takes a while to adjust the rear suspension.
  17. #15
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: Park light bulb
    Correct. The US DOT considers that adequate. Even the active adjusting ones aren't perfect.
    With the correct headlight aiming & projectors, they probably are right.
  18. Remove Advertisements
