2007 STS traction control
Results 1 to 14 of 14
Like Tree2Likes
  • 1 Post By carter's_sts
  • 1 Post By curtc
Cadillac STS Forum - 2005 through 2012 Discussion, 2007 STS traction control in Past Cadillac Vehicle Discussion; My 07 STS' traction control comes on periodically, and my car will move a bit slower for a few seconds. ...
    fdhall3 is offline Cadillac Owners Member
    May 2014
    7
    My 07 STS' traction control comes on periodically, and my car will move a bit slower for a few seconds. Anyone have an idea why this happens?
    Thanks
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,055
    Re: 2007 STS traction control
    When does it come on? Is it completely random? T/C retards timing and will cause power loss to prevent further slippage, that part is working as designed. But, if it is activating itself for no reason there's an issue. The T/C system gets readings from each wheel speed sensor, they reside in each of the hub assemblies so my guess would be an intermittently failing wheel speed sensor. The tricky part will be figuring out which one as you'll need to replace the entire hub assembly.
    May 2014
    7
    Yes, it is random.
    mkosharkii's Avatar
    mkosharkii is offline Cadillac Owners Fanatic
    Automobile(s): 2007 SRX4 N* MRC, 2014 Corvette Z51 3LT, 1979 KZ1000 LTD
    Sep 2011
    Norfolk, VA
    32
    223
    No codes? Mine was doing the same thing, but it threw codes for the left rear WSS. Random low speed ABS actuation along with traction and stability control issues.
    May 2014
    7
    No codes.
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,264
    Does your code reader display anything other than engine codes? It takes special stuff to read ABS, body, and other system codes. You need a TECHII or something like AutoEnginuity to get the job done.
    Don't mess with Binky Bear!
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,055
    most can only read power train codes, you'll need one that can read chasis codes.
    carter's_sts is offline Cadillac Owners Connoisseur
    Automobile(s): 06 STS-V & 06 STS 4 (sold 2016)
    Jun 2009
    2,003
    Mine does it sometimes when I'm turning and I hit a bump at the same time. It's done it since I got it, but its fairly rare for me.
    Dudes_99 likes this.
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,055
    Quote Originally Posted by carter's_sts View Post
    I would consider that normal as doing so is giving off a false slip reading to the wheel speed sensor(s). If you're driving straight on a smooth road and it randomly kicks in, you got issues.
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    My wife's car did this. It was worse on right turns & on rough roads.
    A damp on-ramp could be downright dangerous, despite traction and stability control.
    The cause... rock-hard Michelin Energy tires.
    I'd try new shoes.
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,055
    Just had a thought on this. Are you using stock wheels/tires? I ask because if the outside diameter of aftermarket wheels/tires is smaller than original it may trigger TC to engage as it thinks you're slipping due to the higher amount of revolutions.
    May 2014
    7
    Traction control still coming on at random. Positive not original tires.....problem?
    STS-REAPER is offline Cadillac Owners Member
    May 2012
    24
    Same issue, dealer said it was bad hub& bearing along with bad abs valve and module..
  16. #14
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    After replacing the hub assembly & wheel speed sensor the ABS valve & module might not be so bad.
    Any other signs of bearing issues? They aren't uncommon with the STS. Try some turns in a smooth quiet parking lot with the windows down. Any bearing noise?
    If on right turns, suspect LR hub.
  17. Remove Advertisements
