power steering non-existant at low rpms, ok at higher rpms. ???
Results 1 to 10 of 10
Cadillac STS Forum - 2005 through 2012 Discussion, power steering non-existant at low rpms, ok at higher rpms. ??? in Past Cadillac Vehicle Discussion; took a 2 hour ride and arrived home fine. next day, power steering is very hard at low rpm but ...
    TOPLESSCAD is offline Cadillac Owners Member
    Automobile(s): 2007 sts
    May 2014
    3
    took a 2 hour ride and arrived home fine. next day, power steering is very hard at low rpm but when I raise rpms wheels turn with a bit more effort than normal. I do not have any bad codes, no leaks and no weird noises. power steering fluid is reading where it should be. I have new belts, there is no slipping issues with the pullies. any ideas would be helpful.
    2007 STS4
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,263
    Re: power steering non-existant at low rpms, ok at higher rpms. ???
    Power steering pump is shot. A very common problem.
    Don't mess with Binky Bear!
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,697
    Quote Originally Posted by TOPLESSCAD View Post
    2007 STS4
    Hi TOPLESSCAD,
    I apologize for the difficulties you are experiencing with your power steering. I see that you are looking for some feedback from the rest of the forum. If you would like some additional support, feel free to PM me your VIN, mileage, and contact information and we can further discuss your concerns.
    Have a great night,
    Austin J.
    Cadillac Customer Care
    May 2014
    3
    thanks dkozloski, that was my first guess. is there any way to test the pump?
    hello Austin. first thing, don't know how to PM on this site. second, here is my vin and mileage: 1G6DW6775011xxxx, 120,821 miles. since you are Cadillac customer care, how common a problem is this? I have read that it is quite common and a fellow cadillacforums user also agrees. has Cadillac modified the pump to eliminate this problem in newer vehicles? thanks for any help you can give me.
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,537
    Its less common in the cars with the ZF steering option.
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Quote Originally Posted by Ludacrisvp
    ZF is the rack not the pump. Mine failed and I'm ZF.
    Dino1SG is offline Cadillac Owners Fanatic
    May 2014
    114
    There is a special service tool called a power steering system analyzer which can be hooked into the system to provide assistance With diagnosis by giving pressure readings.
    scott9001 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 sts N* 1965 coupe deville
    Aug 2011
    26
    364
    i had the same problem and I went on a drive about 2.5 hours to the cottage and got there pump would wine at higer rpm like a super charger, hahah and no assist at idle it ended up being the pump had to buy some pittings at the local parts shop to get a gauge in line to read the pressures was more of a pain in the ass than anything. if I was to do it again id just put the pump on they are not that exspencive through nappa if you are cappible of putting the pump on yourself
    May 2014
    3
    UPDATE, OK gentlemen, I replaced the power steering pump and car is doing fine. Works as it should. thank you all for your input and drive safe.
    PS the bolt behind the bracket for pump was a pain in the butt. my hands are too big to squeeze in and loosen, have a friend with skinny hands take that one out for you if you decide to do it yourself otherwise it was easy.
    dannyquest is offline Cadillac Owners Fanatic
    Mar 2012
    columbus ohio
    382
    TOPLESSCAD, What was the cost for the power steering pump and where did purchase it. Danny
  13. Remove Advertisements
