V Cluster in a Non V Car...
Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By 1BadCadSTS
Cadillac STS Forum - 2005 through 2012 Discussion, V Cluster in a Non V Car... in Past Cadillac Vehicle Discussion; http://www.ebay.com/itm/281305381687...84.m1439.l2649 Price was too good to pass up. I should also note based on the speedo read out this has ...
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Price was too good to pass up. I should also note based on the speedo read out this has to be a Canadian cluster (super cool to see 260 as the read out on the speedo, clearly I can toggle between Standard and Metric so I don't foresee it being an issue. Guess we will finally be able to find out if a non V cluster with its additional information such as Oil Pressure and Trans Temp will work on a Non V Car.
    I already can confirm that a 5 speed cluster WILL create an issue on a 6 speed cluster car. When putting it in manual mode it simply displays M5 all the time. It still shifts normally however it will not display the correct gear (tested this on fathers 07 installing my 05 cluster to see if the MPH digital read out would go away since he has HUD, for the record it did not and DID display MPH on all the HUD, Analog and Digital read outs.).
    I would PRESUME since this is for a 6 speed car (all Vs were 6 speed) that the car will have some issue with manual mode for the 05-06 crowd with the 5 speed trans. I also have NO idea what its going to do under the digital boost read out on the DIC (I would think it will just stay dead at zero).
    Feedback to follow... one of these days Ill stop buying more projects until I finish previous ones... Still hoping to get the HUD installed in the next few weeks.
    Ludacrisvp likes this.
    carter's_sts is offline Cadillac Owners Connoisseur
    Automobile(s): 06 STS-V & 06 STS 4 (sold 2016)
    Jun 2009
    1,955
    Re: V Cluster in a Non V Car...
    Dang that was cheap. Keep us posted on how it works.
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,496
    Any idea how many miles / km on that one? Curious when that V lost it's life. Assuming this works will you use the 260 kph speedo in mph mode (making it a 260mph speedo) or will you find a proper USA speedo from a v instead.
    If the sensors are there in a non v hopefully the cluster can pull the info.
    What year did the cluster change appearance was it 08?
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Quote Originally Posted by Ludacrisvp
    08 cluster got a facelift that's it really plus the ability for other options. 05-07 are the same but 07 v8 only are programmed for the 6 speed.
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,496
    Well hopefully it works.
    I'd rock a v cluster just to get the couple extras for stats and deal with a 0 boost gauge.
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Exactly. I won't like the auto stick display not working though.
    Also I forgot to answer I have no idea of mileage per listing its unknown. The more I look at it it looks like its missing the plastic widow as well.
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,496
    Quote Originally Posted by 1BadCadSTS View Post
    So get a 6spd...
    It does indeed appear to be missing that cover. Oh well. Now you should convert this to using the white / blue LEDs instead of the orange ones in the DIC to match your HVAC controls.
    B1n2fra's Avatar
    B1n2fra is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 1SG STS v8 awd
    Nov 2011
    Chicago
    36
    502
    I thought about using an srx cluster because it has the blue leds in the dic display. It looks exactly like the sts cluster.
    [QUOTE="1BadCadSTS;12296921"]http://www.ebay.com/itm/281305381687...84.m1439.l2649
    Price was too good to pass up. I should also note based on the speedo read out .
    For that price I would of took a shot at it too.
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Quote Originally Posted by B1n2fra
    Same. I believe the wiring was slightly different which is why I opted against it. I converted my hvac to blue by swapping the smleds.
    JJJake is offline Cadillac Owners Member
    Automobile(s): 2008 STS V8
    Aug 2013
    38
    17
    If anything it would show a negative number due to vacuum. I doubt there is a sensor in place to even get that number generated though.
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Doesnt read negative, its a digital read out from 0-16?
    I am sure it will be just a dead gauge always out at zero.
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    It a bust.
    Cluster arrived. They shipped it in an unpadded envelope. Both side mounts were busted and it was missing the front plastic lens. All gauges are dead. Speedo tach temp fuel everything. I filed for a refund based on damages.
  15. Remove Advertisements
