Replacing ignition switch on 2006 Cadillac STS
Results 1 to 3 of 3
Cadillac STS Forum - 2005 through 2012 Discussion, Replacing ignition switch on 2006 Cadillac STS in Past Cadillac Vehicle Discussion; I have been having electrical problems lately , battery discharging and car won't start. Keep getting jump starts etc etc... ...
    mihamilt is offline Cadillac Owners Member
    Automobile(s): None
    Mar 2014
    None
    4
    CoolReplacing ignition switch on 2006 Cadillac STS
    I have been having electrical problems lately , battery discharging and car won't start. Keep getting jump starts etc etc... Well I'm at the point now where a diagnostic has given me the code to replace ignition switch and the shop that gave me te codes says that this is dealership work. So here is where I stand today... I am going to have my car towed to a GM dealership in the morning, and tell them to replace my ignition switch. My question to all of you is Does anyone know of a requirement to have the switch re-programmed by technician after switch is replaced? The switch cost no more than $100.00 and that's the high price, does anyone know of the approx. labor time ? I am also having the battery replaced also, I estimate that my cost should be upwards and around $ 350.00 max does this sound correct? Before dealing with the dealerships I like to have a good estimate of whats being done because a lot of times they just tell you anything. Any and all help is appreciated.
    THANKS ALL !!!
    ddalder's Avatar
    ddalder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-4 N* 1SG, 08 DTS Luxury II, 04 Bonneville GXP N*
    Aug 2008
    Canada
    2,827
    Re: Replacing ignition switch on 2006 Cadillac STS
    A generous amout of time to replace is 30 minutes, but most facilities will charge a minimum of 1 hour. There is no programming required. What code(s) have led you to believe this is necessary? This would be a very uncommon problem.
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    2005-2007 STS ignition switch tended to crack. Mine was replaced under warranty. The new design is noticeably more sensitive. Quite often, after driving my wife's car, I'll press the off (lower) end of the switch briefly enough to shut off my car (by habit) and her car keeps running.
