Page 1 of 2 12 LastLast
Results 1 to 15 of 22
Thread: Ticking sound when on load
    No Quarter's Avatar
    No Quarter is offline Cadillac Owners Fanatic
    Automobile(s): 2009 CTS-V, 2006 STS 3.6
    Sep 2013
    Denmark
    144
    My 3.6 has had a strange noise since I bought it, most of the time, and it's getting more frequent and strong. When acceleration semi hard, more than just normal driving, I hear like a higher picth drum roll from engine room. Could sound like a fast ticking PCV (which I don't think this car has?) When revving it in Park, there's no sound, only when under load.
    It's not always present so can't be engine bearings etc., but it's more and more frequent.
    Any suggestions?
    Thanks
    C&C's Avatar
    C&C is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac XT5 (2017)
    Feb 2008
    Mount Pleasant, SC
    66
    1,961
    Re: Ticking sound when on load
    It sounds like it is pinging (octane too low or carbon deposits in the cylinders). Have you changed (or tried) some higher octane fuel to see if the symptoms disappear or mitigate.
    No Quarter's Avatar
    Sep 2013
    Denmark
    144
    I don't think it's pinging, because the volume changes, and pinging seems very consistent, and it doesn't really follow RPMs. And same gas as usual (95). On the way home I tried WOT, and as soon as it gets above 4000 rpm, where it really gets power, the noise is gone, comes back under 4000 rpm. How does the engine change the power such above 4000, is it different intake channels or camshaft positioning?
    Keep suggestions coming
  5. #4
    KRSTS Guest
    Why are you using 95 (is that 95 octane) in a 3.6 L engine?
  6. #5
    PontiacV8's Avatar
    PontiacV8 is offline Cadillac Owners Fanatic
    Automobile(s): 2015 Camaro 2SS, Sold: 2006 STS (EXP) 1997 Seville STS (EXP)
    Dec 2006
    Germany / Nordhorn
    423
    Quote Originally Posted by KRSTS View Post
    ...he is in europe...in europe we are using an octane rating for gasoline by RON (research octane number)...
    ...95 RON is about 90 - 91 US-gasoline (AKI - (R+M)/2 or PON - pump octane number)
    http://en.wikipedia.org/wiki/Octane_rating
  7. #6
    KRSTS Guest
    87 R+M/2 octane is all that is needed in that engine. Higher octane is a waste of $ unless you either can't get a lower octane in Europe or it actually cost more?
  8. #7
    PontiacV8's Avatar
    Dec 2006
    Germany / Nordhorn
    423
    ...lowest octane rating in most western european countries is 95 RON...
    ...ok...back to topic
  9. #8
    KRSTS Guest
    Thanks for that information
  10. #9
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Check the oil level. If low, add to the mark.
    If it's not low, have the timing chains checked for wear.
    Good luck.
  11. #10
    Mar 2012
    columbus ohio
    382
    How do you check the timing chain for wear on newer engines. On older engine its easy. Just turn the crank shaft left then right to check the slop. Danny
  12. #11
    Ludacrisvp's Avatar
    Ludacrisvp is online now Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,548
    not sure, do you have the V6 or V8 ... if you have the V8 and haven't run low oil I wouldn't worry about it.
    If you have the V6 then I would worry.
  13. #12
    Mar 2012
    columbus ohio
    382
    I have the V-6. It runs great. Danny
  14. #13
    Mar 2010
    Detroit, USA
    12,711
    Quote Originally Posted by No Quarter View Post
    Any suggestions?
    Thanks
    Sincere apologies to read of your concerns. I understand that you're seeking thoughts and opinions, but send us a message if you want to take it a step further and get an official diagnosis. I will then reach out to a Customer Experience Manager at your desired dealer for additional assistance in these matters. If not, feel free to PM your VIN so we may check resources for any related field actions.
    William R.
    Cadillac Customer Care
  15. #14
    Four Fins's Avatar
    Four Fins is offline Cadillac Owners Member
    Automobile(s): 61 Sedan, 06 STS
    Jul 2012
    35
    40
    I have this same problem and have yet to figure it out. I do monitor the oil but I haven't checked the timing chain yet which are notorious for these v6's.
  16. #15
    No Quarter's Avatar
    Sep 2013
    Denmark
    144
    Quote Originally Posted by Four Fins View Post
    How long have you had it?
  • You may not post replies
