Remote start not working
Results 1 to 9 of 9
Cadillac STS Forum - 2005 through 2012 Discussion, Remote start not working in Past Cadillac Vehicle Discussion; I have a 2006 Cadillac STS V8 and my remote start hasn't worked ever since I got it but seeing ...
    Jneedom14 is offline Cadillac Owners Member
    Automobile(s): STS
    Mar 2013
    41
    42
    I have a 2006 Cadillac STS V8 and my remote start hasn't worked ever since I got it but seeing that I don't wanna have to go out and start it next winter I want it to work. Now I have the option set in the navigation for both drivers but its still not working. I get the flashing of the lights but no start. I just want to get the Remote Start feature to work. If any of you have any tips/suggestions please tell me I would highly appreciate it.
    carter's_sts is offline Cadillac Owners Connoisseur
    Automobile(s): 06 STS-V & 06 STS 4 (sold 2016)
    Jun 2009
    2,034
    There is a whole list of conditions that can disable it. They are listed in the manual. I can't remember them all.
    Switch in the glove box set to Valet.
    Trouble codes stored. Have to pull codes with a scan tool.
    Check Engine light on.
    Hood switch not in hood closed state.
    Only FOBs programmed as 1 and 2 can remote start.
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    Re: Remote start not working
    Out of the manual:
    The remote start feature will not operate if any of the following occur:
    • The check engine light is displayed. See “Check Engine Light” under Malfunction Indicator Lamp on page 252.
    • The valet lockout switch is on.
    • The keyless access transmitter is in the vehicle.
    • The vehicle’s hood is open.
    • The vehicle personalization feature is not enabled.
    • An unauthorized vehicle entry or a vehicle theft was attempted.
    Also, a fob that's not programmed as fob 1 or 2 won't be able to remote start the car.
    funk_drum is offline Cadillac Owners Member
    Automobile(s): 2008 STS4
    Jan 2014
    40
    When I got mine the dealer said to lock the car first, then start. I've never tried it any other way tho.
    Jun 2009
    2,034
    Yes, you have to press lock once, then hold remote start.
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Press lock until you see the tail/parking lights. Press & hold start.
    Most common reason is fob matched as 3 or 4 (originals lost and replacements not properly matched). See the 'Sticky' thread at the top of the forum for a link to the correct procedure (#3 in my write-up).
    Automobile(s): STS
    Mar 2013
    41
    42
    I cant find it can you find the link for me?
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,559
    http://www.cadillacforums.com/forums...ml#post1894623
    http://www.cadillacforums.com/forums...ml#post1818192
    Also:
    The remote vehicle start (RVS) System WILL NOT operate if any of the following conditions are present:
    ^ A current vehicle DTC that illuminates the malfunction indicator lamp (MIL) is set - obtain vehicle DTCs.
    ^ Keyless Entry Transmitter is not Operational.
    ^ The vehicle is in Valet Mode.
    ^ RVS is Disabled through Vehicle Personalization.
    ^ More than 2 Remote Starts have been attempted.
    ^ The HAZARD switch is in the ON position.
    ^ A current HAZARD switch DTC is set.
    ^ A current HOOD AJAR DTC is set.
    ^ Rear compartment lid is ajar.
    ^ Any Door is not locked.
    ^ The Content Theft Deterrent (CTD) system detects an alarm trigger.
    ^ Engine RPM greater than 0 Detected.
    ^ Excessive Coolant TEMP is registered.
    ^ Accelerator pedal position greater than 0 percent.
    ^ Vehicle is not in PARK.
    ^ A current Vehicle Theft Deterrent Malfunction DTC.
    ^ A current Automatic Transmission Shift Lock Control System DTC is set.
    ^ A vehicle speed sensor signal is detected by the ECM.
    ^ Vehicle power mode is incorrect.
    ephr0514 is offline Cadillac Owners Member
    Mar 2014
    4
    This info was very helpful. Yes lock first then it will start. Has been extremely convenient during winter. Envy of all of my Co workers.
  12. Remove Advertisements
