Slow Crank, no start issue.
Results 1 to 15 of 15
Cadillac STS Forum - 2005 through 2012 Discussion, Slow Crank, no start issue. in Past Cadillac Vehicle Discussion; So for the past two months I have been battling a slow Crank/no start issues which has left me stranded ...
    06WhiteDiamond is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Cadillac STS-V
    Jan 2012
    28
    320
    So for the past two months I have been battling a slow Crank/no start issues which has left me stranded now quite a few times.
    Basically the car will crank but not turn over on the first start. It usually turns over on the second start but sometimes even that doesn't do it.
    I have replaced the battery twice now as the slow Crank leads me to believe it's a battery issue. At this point I'm quite certain it is not the battery. It is almost as if the starter motor is pulling too many amps, a few cranks and the car will drain the battery in no time and leave me stranded.
    I have checked and cleaned all ground terminals. The battery is brand new and no corrosion can be found throughout the engine bay.
    At this point I am leaning towards a starter motor and just picked one up from the local GM dealer.
    Can anybody chime in on what else could be wrong? 2006 sts v6 awd
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,536
    Re: Slow Crank, no start issue.
    I thought I recalled another person mentioning needing a starter at some point.
    Maybe the Alternator is under-performing and not charging the battery back up well enough during the drive to be able to withstand the power draw from the starter.
    While that is annoying you should figure out why it doesn't start during the first attempt as it should.
    Does it crank for about 10 seconds or so then you hit the start button again and then it will start?
    maybe weak fuel pump / dirty fuel filter starving the engine too much to start easy?
    I'm not sure if these cars allow us to 'give it gas' during startup but maybe next time see if putting some pressure on the pedal will get it going.
    CadiTamer is offline Cadillac Owners Fanatic
    Automobile(s): 2006 STS 3.6 RWD
    Dec 2013
    22
    117
    I'm betting you probably have one of two things happening: Low battery voltage for some reason, or a bearing in the starter is shot.
    When the car is running, does it run well? Can you drive it hard without issues? If so, it'll likely be something wrong with the starter or charging system. A slow crank can cause a no start, as the engine has to be spinning fast enough to fire on a cylinder to get running. If it doesn't crank fast enough, it won't start.
    You can try giving it gas while it's starting. You should be able to give it up to 80% throttle, but don't floor it, as that'll just put it into "clear flood mode" which is meant to get rid of extra fuel that may have built up in the cylinders during several failed starts.
    Jan 2012
    28
    320
    Quote Originally Posted by Ludacrisvp View Post
    Yes it does crank for about 10 seconds and then stops as it will not fire. Sometimes it takes 3-4 cranks to even get it started. This severely drains my battery though.
    Fuel filter and plugs were done last month so I can rule out spark or the fuel filter. Could be the pump but the car runs perfectly fine when it manages to turn over.
    Quote Originally Posted by CadiTamer View Post
    Car runs just fine when it manages to turn over. Can drive it hard and don't feel any hesitation.
    Alternator seems to be working, I'm leaning towards the starter.
    An interesting thing to note is that when I get a friend to come boost me. All the cranks I have attempted drain the battery, if I hook up the cables the car will start up. It's almost as if the starter is pulling too many amps and when feeding off a running car it fires right up.
    dannyquest is offline Cadillac Owners Fanatic
    Mar 2012
    columbus ohio
    382
    I vote for a new bigger battery with more amps. Wal-Mart battery with 850amps. Work for me. Danny
    Jan 2012
    28
    320
    Quote Originally Posted by dannyquest View Post
    Battery is 1000 cranking amps and 800 cold cranking amps, replaced twice within the last two months.
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,536
    I'd say starter is either weak or has a bad cable running to it that can't provide enough amperage to the starter (possibly corroded wires perhaps internally that you can't see).
    Dec 2013
    22
    117
    Yeah, that brings you to starter or cables to starter. There's a remote chance that the starter cable could be corroded/damaged, which isn't letting full power get to the starter. Corrosion means higher resistance, which means higher amperage draw to spin the starter slower.
    Jan 2012
    28
    320
    *Update*
    Car is at my mechanics, we just pulled the starter. The shaft inside the starter broke and created a ton of play which is why the car would constantly crank and not fire as the starter could not properly ingage due to play in the shaft.
    I am honestly completely suprised that I was still able to start the vehicle with the starter in such shape.
    I took some pictures for your viewing pleasure. I also took a video to show the play in the shaft for future members.
    KRSTS Guest
    How did the starter get so corroded?
    Jan 2012
    28
    320
    Quote Originally Posted by KRSTS View Post
    Too be honest I have no Idea, I stored the caddy last year and drove my beater. Hard to give up the luxuries of driving a caddy, especially in winter. Most of the underside is rust free so I'm not sure how it got so corroded.
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    This does seem consistent. 4 or 5 attempts should not seriously tax a good battery. Too bad it took so long for a solid failure to lead to a root cause & final resolution.
    I hope you now have many years of reliable starts. That is more typical.
    rodnok01's Avatar
    Feb 2012
    NC
    6,673
    That starter looks 20 yrs old, surprised it worked a lick. People can say what they want but GM starters work when they shouldn't.
  16. #14
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,536
    Do you or the car live on the coast? Thinking salty air may have played a role in its corrosion.
  17. #15
    Jan 2012
    28
    320
    Toronto, Canada
    They salt like crazy up these ways. I try to wash it off as often as I can but this winter took quite a beating on my baby. Not a big deal because I plan to upgrade to a V, unfortunately they are super rare around here.
  18. Remove Advertisements
