Steering wheel buttons help
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Like Tree1Likes
Cadillac STS Forum - 2005 through 2012 Discussion, Steering wheel buttons help in Past Cadillac Vehicle Discussion; Anyone knows how to pop open the buttons on the steering wheel? Just like every Cady, I have only one ...
    atlrus is offline Cadillac Owners Fanatic
    Automobile(s): 04 escalade, 07 STS4 V8
    Oct 2009
    109
    Just like every Cady, I have only one button with working light out of the four
    I am sure I can find some LEDs to solder, but not sure how the buttons come off, if at all. Any advice?
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Quote Originally Posted by atlrus
    Remove air bag
    Remove 3 mounting bolts
    Whole V steering wheel switch assembly needs removed to open up and service the non serviceable LEDs.
    Oct 2009
    109
    Re: Steering wheel buttons help
    Quote Originally Posted by 1BadCadSTS View Post
    Remove air bag
    The buttons don't pop up? Are you certain that I need to disassemble the steering wheel to remove the button covers?
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Sure they can pop up but youll never get them back down because youd have to of broken it.
    Never said you have to remove the steering wheel.
    Do it right do it once.
    Not to mention your heater relay is mounted in the v assembly. Only way to remove that to remove the v switches is to pull the bag.
    ddalder's Avatar
    ddalder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-4 N* 1SG, 08 DTS Luxury II, 04 Bonneville GXP N*
    Aug 2008
    Canada
    2,827
    I thought the pre-2008 steering wheel controls used incandescent lamps... I could be wrong, but this would explain the OP's complaint. It is extremely unlikely that LED's in these would fail.
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Quote Originally Posted by ddalder
    Sorry you are corret. They are however non serviceable. It's not a bulb that's user replaceable without "modification".
    ddalder's Avatar
    Aug 2008
    Canada
    2,827
    As you say, possible but requires some skill in disassembly and soldering along with sourcing the correct bulbs.
    Oct 2009
    109
    Soldering and finding he bulbs is not an issue, but the airbag is a deal-breaker for me
    Thanks anyways
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Thanks anyways
    Why? I've had mine off 3 times at least and I'm sure Darcy has had his off even more.
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,539
    Pulling the airbag isn't that bad... basically disconnect battery, stick some long handled flat blade screwdrivers into the holes in the back of the wheel and give a little twist and the bag comes off.
    I took the bag off of my deville wheel probably 5 or 6 times when I was converting it from a non heated to a heated wheel and when I had to replace failed switch lamps.
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Quote Originally Posted by Ludacrisvp
    Luda about this though a bit off topic. Did you swap the sir coil to one with heated wheel? How did you power it. Its a mod I wanted to do to my Seville sts for my mom. Bought the wheel years ago and bench tested it. Never installed it though. Another project I bought to start and never did. This is why I have so much crap....
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,539
    I carefully pulled the clockspring (the "sir" coil) apart making sure it was dead center for rotations after putting it back together (so it wouldn't shred while driving).
    I grounded the heater to the wheel itself and ran power from the battery and up the column where I used one of the non-used conductors in the current clockspring to power the heater.
    Basically there are (IIRC) about 6 or 7 conductors going through the non-heated version and not all of them are used, so I soldered a wire in on each side of the spring using the one empty conductor lane and it worked perfectly.
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    I may finally do this... (Which means in a year ill think about it hahaha)
    Ludacrisvp likes this.
  16. #14
    cadi509's Avatar
    cadi509 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS V Tango int
    Jan 2010
    Yakima, Wa
    28
    2,337
    Anyone know where I can find the far left button to replace? the light is out and irritates the hell out of me.... It's the search seek button
  17. #15
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Cannot replace one button. It's the whole assembly. Also Vs are different they have a carbon fiber like switch assembly. Non V is color coded "wax" cleared plastic.
  18. Remove Advertisements
