06 sts Adaptive cruise control / heated steering wheel not working help
Results 1 to 13 of 13
Cadillac STS Forum - 2005 through 2012 Discussion, 06 sts Adaptive cruise control / heated steering wheel not working help in Past Cadillac Vehicle Discussion; I have a 06 sts the heated steering wheel quit work as well as the adaptive cruise. It shows a ...
    richric is offline Cadillac Owners Member
    Dec 2013
    5
    I have a 06 sts the heated steering wheel quit work as well as the adaptive cruise. It shows a car on the HUD but can't set the cruise. When u try u get nothing on the DIC no messages or errors. Can anyone help me on this one thanks
    cadillacmike68's Avatar
    cadillacmike68 is offline Cadillac Owners Connoisseur
    Automobile(s): 68 DVC, 96 FLTWD Brg, 09 STS N* Platinum, 11 CTS Premium
    Jan 2005
    Left the desert - Back in FL
    55
    1,291
    Re: 06 sts Adaptive cruise control / heated steering wheel not working help
    That's most likely a problem with the wiring or membrane switches on the left side of the steering wheel, where those buttons are.
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,525
    does it ever say "RADAR CRUISE NOT READY"?
    Or rather did it ever?
    When i was buying my car the cruise was totally dead, no messages, nothing.
    Turned out the multifunction lever was bad, my car has had this fail twice and I think it is doing it again as my cruise died again last night, a quick reboot of the car got it going again but it will get to the point where it just stops again.
    Carvone is offline Cadillac Owners Fanatic
    Automobile(s): 07 STS 1SG & 10 STS 1SG
    Nov 2008
    Florida
    55
    268
    Quote Originally Posted by Ludacrisvp View Post
    Maybe you just dont know how to use cruise control...
    R(On): Move to this position to turn on the system.
    + (Resume/Accelerate): Move to this position to
    make the vehicle resume a previously set speed or
    to accelerate when cruise is already active.
    T(Set/Decrease): Press this button to set the
    speed or to decrease the speed when cruise
    is already active.
    With cruise control, a speed of about 25 mph
    (40 km/h) or more can be maintained without
    keeping your foot on the accelerator. This
    can really help on long trips. Cruise control does
    not work at speeds below about 25 mph (40 km/h).
    If your vehicle is in cruise control when the
    Traction Control System (TCS) begins to limit
    wheel spin, the cruise control will automatically
    disengage. See Traction Control System (TCS) on
    page 323 and StabiliTrak® System on page 326.
    When road conditions allow you to safely use
    it again, you may turn the cruise control back on.
    1. Move the cruise control switch to on.
    2. Get up to the speed desired.
    3. Press in the set button at the end of the lever
    and release it.
    4. Take your foot off the accelerator pedal.
    This light on the
    instrument panel cluster
    will come on while
    cruise control is on.
    Reducing Speed While Using Cruise
    Control
    There are two ways to reduce your speed while
    using cruise control:
    • Press in the button at the end of the lever until
    you reach the lower speed desired, then
    release it.
    • To slow down in very small amounts, briefly
    press the set button. Each time you do this,
    you will go about 1 mph (1.6 km/h) slower.
    Passing Another Vehicle While Using
    Cruise Control
    Use the accelerator pedal to increase your speed.
    When you take your foot off the pedal, the
    vehicle will slow down to the cruise control speed
    you set earlier.
    Using Cruise Control on Hills
    How well the cruise control works on hills depends
    upon the vehicle speed, load, and the steepness of
    the hills. When going up steep hills, you might have
    to step on the accelerator pedal to maintain the
    vehicle’s speed. When going downhill, you might
    have to brake to keep the vehicle’s speed down.
    Applying the brake will turn off the cruise control. If
    you need to apply the brake due to the grade of the
    downhill slope, you might not want to attempt to use
    your cruise control feature.
    Ending Cruise Control
    To end a cruise control session, step lightly on the
    brake pedal.
    Stepping on the brake pedal will end the current
    cruise control session only. Move the cruise control
    switch to off to turn off the system completely.
    Erasing Speed Memory
    When you turn off the cruise control or the
    ignition, the cruise control set speed memory
    is erased.
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,525
    Quote Originally Posted by Carvone View Post
    If you want to be a dick thats fine be a dick.
    There are many people out there that have no idea on how to program their homelink systems, it is often asked on the forums.
    malatu's Avatar
    malatu is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS 3.6 AWD
    Dec 2005
    1,005
    From day one, my cruise control becomes inoperative for no apparent reason. Though, it always dies when I am using it to speed up and slow down numerous times in a short period of time.
    I have to pull over, turn the car off and restart.
    It's annoying but it doesn't happen often. I've learned to play less with the cruise control.
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,525
    Quote Originally Posted by malatu View Post
    Might be a flaky multifunction lever like mine they are about $60 at the caddy dealer for the part.
    Mine has been replaced twice, and probably will be again on Monday as it has started acting up again.
    I got to the point where I would just reboot the car while driving, get to a point where nobody is behind you and you have enough speed built up to not slow way down. Pop to N turn off engine, lightly touch the brake and restart car, move to D again and continue along your way and set the cruise.
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,683
    Quote Originally Posted by richric View Post
    Hello Richric,
    I’m sorry to hear that you are having issues with your vehicle. Although, it’s great to see that you are getting some helpful feedback from the community. If I can assist you by setting up an appointment with your dealership please do not hesitate to reach out to me. I hope to hear from you soon.
    Gregory W.
    Cadillac Customer Care
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,525
    Sitting at the dealer now.
    This one is an exclusive caddy dealer (they used to do Saab as well but they don't exist any longer) and apparently they only offer loaners to owners still under GM warranty so here I sit waiting.
    They are going to start from "square one" this time and will not tell the service tech about any of the car's service history from the other dealers. That seems a bit odd to me but whatever I guess.
    I'm not feeling too hopeful as the car was in the back for a few mins and the service writer asks me if I have changed the front caddy logo out to a different one ... It's got the stock grille and stock 08+ ACC radar dome.
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,041
    Are you at Key?
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,525
    Damnit I was intending to go to key for my next service visit.
    I'm at Morries Cadillac Saab but just Cadillac now. It used to be Anderson Cadillac back in the day. Came here as it was the only dealer I could think of at the time as this is where my parents got their 04 SRX and it seemed like we had a decent experience ... Completely spaced on Key Cadillac.
    Still sitting here btw. Probably will be until around 5 or later at this rate.
    They aren't willing to touch anything cruise related. As they cannot reproduce issue nor are they finding any codes. They are telling me that I will have to drive in during this condition before they will be able to do anything.
    They are changing the bad LF TPMS and fixing an oil leak around the rear driver side axle under my service contract.
    They said there is play in the right rear hub but not enough that a warranty would cover it (apparently GM spec says 1/4" of play needed) and they want to do the rear diff vent mod for around $500 as the side of the diff is wet.
    I really really have to remember to go to key next time.
    Mar 2010
    Detroit, USA
    12,683
    Hello malatu,
    I am sorry to hear that you are experiencing a concern with your cruise control becoming inoperative as well. If you are planning on taking your vehicle into the dealership to have them look into this, please feel free to private message me if you would like any assistance in setting up an appointment and working with the dealership. I will be sure to look out for your future updates.
    Gregory W.
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    I've had the Radar Cruise go not ready a few times. Once was just because is was covered with heavy wet snow. What was I trying it for, anyway?
    Another time was after 30 minutes of extremely heavy rain. I figure some water worked its way into a connector and had it persisted, I was under warranty, so I would have had a dealer disassemble the wiring and look for a miss-joined connector or the like.
    Just a couple days ago, I think some water froze on (under?) the radar dome cover and it happened again. The car was getting caked with salt, anyway. It's looking my like the picture again, now. I've found the cruise to be amazingly tolerant of poor conditions. I've heard the SONAR-based ones aren't nearly as reliable.
  16. Remove Advertisements
