Need location and recommended procedure to replace the ECT Sensor on 2006 STS 4.6L - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Like Tree2Likes
Cadillac STS Forum - 2005 through 2012 Discussion, Need location and recommended procedure to replace the ECT Sensor on 2006 STS 4.6L in Past Cadillac Vehicle Discussion; Originally Posted by CadiTamer Judging by that picture, if you just pull the transmission you'll have easy access to it... ...
  1. #16
    daddy_o's Avatar
    daddy_o is offline Cadillac Owners Fanatic
    Automobile(s): 2010 STS 3.6 AWD 1SB Black Cherry
    Oct 2011
    P. R. of MA.
    55
    356
    Re: Need location and recommended procedure to replace the ECT Sensor on 2006 STS 4.6
    Quote Originally Posted by CadiTamer View Post
    I would recommend a 2" hole saw from the inside passenger firewall....just sayin...
  2. #17
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    It looks to me like a chance to go buy a new tool; one of those fiber-optic see-inside/around-a-corner probes. Harbor Freight has a high-res digital inspection camera with recorder (to show us how it's done) for $200. Their stuff isn't always top quality, but the prices are usually competitive and the warranty is good.
    Link to Inspection Camera
    If you have one of their stores in your area, their ad always has a coupon for a free $5-10 item and 20-25% off anything.
  3. #18
    Carvone is offline Cadillac Owners Fanatic
    Automobile(s): 07 STS 1SG & 10 STS 1SG
    Nov 2008
    Florida
    55
    268
    Quote Originally Posted by EChas3 View Post
    That is a good idea to get an eye on the part but you still have to get your hands and tools in there, so your going to have to make room. I had my round and rectangle inspection mirrors out, two droplights and flashlight and couldn't even see the part from the top or bottom.
    It is going to take hours for something that should take minutes. I hope DdPSTS has some luck this weekend and reports back.
  5. #19
    SpeedGP is offline Cadillac Owners Member
    Nov 2013
    27
    13
    I'm in the same boat, it's been randomly displaying no temp and turning my AC off for about two weeks, and this week is about once a day....
    I just ordered the sensor, I hope he gets back and lets us know
    (This gives me a good reason to backflush my heatercore too!)
  6. #20
    curtc's Avatar
    curtc is online now Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,040
    All mine has ever done is render the coolant temp gauge useless, just sits at cold randomly. No issues with AC though. Does it at least once a day.
  7. #21
    DdPSTS's Avatar
    DdPSTS is offline Cadillac Owners Member
    Automobile(s): 2006 Cadillac STS 4.6L
    Feb 2014
    9
    Ok Thanks to all those who commented on this post I was able to find and replace the elusive ECT (Electronic Coolant Temperature) Sensor in about an hour and a half. I had drained the radiator and replaced the thermostat (simple job) earlier in the week and left it sitting on the lift. I recommend that you replace the thermostat when you replace the ECT sensor. The ECT sensor is located on the passenger side, on the back of the engine block close to the firewall. You cannot see it or access it from the top. The diagram sent earlier in the thread shows exactly where it is (Thanks again for those pics I would not have found it otherwise). You do not have to pull or drop the transmission, raise the engine or cut a hole in the firewall. I have a car lift in my garage and if you don't I highly recommend you find a friend that does. Trying this with jack stands could be more difficult but could be done with patience.
    Here is the procedure and I took pics along the way to show where it is and how to get it out. 06 STS Temp Sensor -2.jpg With the car in the air looking between the transmission and the exhaust pipe coming down from the manifold you will find a freezer plug on the block. At the 11 o'clock position of that plug you will see a small male black wire/connector plugged into the black female connector on top of the brass ECT sensor as shown in the picture. There are two ground wires bolted to the block on the right. You can get you hand in there from this angle. Take a long screw driver and slip it under the clip on the connector and with your other hand pull on the connector. 06 STS Temp Sensor Plug -1.jpg Mine came off very easily. Move the cable out of the way and you will realize that there are two fuel lines that are routed directly over the sensor. Take a 2 ft crow bar and gently move and separate the two fuel lines (bending the lines only slightly to make room for the deep socket needed to remove the sensor) You will need an extension of about 23"-24" long on a 1/4" socket wrench. You will also need a knuckle and a deep 3/4" socket (See the pic) Socket wrench extension needed.jpg. Socket and knuckel.jpg
    With the socket in place and the extension at the right angle you can then loosen the sensor. I broke the black plastic tip off the sensor when removing it. 06 STS old and new Temp Sensors - 1.jpg This tells you to be careful when installing and tightening the new one. Keep the extension up close to the transmission or you will put too much pressure on the end of the sensor. Break it off and you'll be back at the auto store buying a new sensor. Slowly and carefully tighten the sensor and install the connector and you are done. I refilled the radiator, started her up and checked for leaks. (No Leaks great! If it leaks simply remove the connector and try to tighten the sensor a little more....careful not to break it). I then cleared the OBDII Check engine light/codes and so far it has done the job. The temperature gauge works again and no check engine light. Thanks again to everyone who contributed to this post.
    Tom's Caddy and RicoX9 like this.
  8. #22
    hmorrowjr Guest
    2006 srx 2006 EOP location
  9. Remove Advertisements
