Spark Plug Change
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By KRSTS
Cadillac STS Forum - 2005 through 2012 Discussion, Spark Plug Change in Past Cadillac Vehicle Discussion; About a month ago I had misfire on cylinder #2. I replaced the coil and while I was at it ...
    KRSTS Guest
    Spark Plug Change
    About a month ago I had misfire on cylinder #2. I replaced the coil and while I was at it decided to replace my spark plugs also. I have the 3.6L V6 DI engine so I did not have to remove the intake plenum. Very easy job. I replaced them with OEM Delco platinum. The old plugs looked OK, but the gap was way wide. My car has 61000 miles. I have been monitoring my fuel use very closely since then and my combined mileage has gone from 17.8 MPG to around 19 MPG. No changes in my driving habits or anything else. Seems like new plugs made quite a difference. I always use top tier gas and an occasional bottle of Techron. Just thought I'd pass this along.
    sub613 likes this.
    Chinny is offline Cadillac Owners Member
    Automobile(s): 2007 STS4 3.6
    Oct 2013
    30
    Thanks for the input, have 76000 on mine and noticed some power loss/engine hesitation at higher rpms. Some research seems to suggest changing the plugs as a start. Alreadt bought the AC Delco plugs just have to change em. Ill monitor the mpgs after too, if i get more thats a bonus.
    AQJ
    AQJ is offline Cadillac Owners Member
    Automobile(s): 2001 Deville and 2009 STS
    Mar 2014
    Re: Spark Plug Change
    KRSTS,
    I have a misfire on cylinder #4 of my 09' STS. Replacing the coil seems fairly simple, but how do I determine where the #4 cylinder is?
  5. #4
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,478
    Quote Originally Posted by AQJ View Post
    KRSTS, I have a misfire on cylinder #4 of my 09' STS. Replacing the coil seems fairly simple, but how do I determine where the #4 cylinder is?
    What engine do you have?
    V6 -or- V8
  6. #5
    daddy_o's Avatar
    daddy_o is offline Cadillac Owners Fanatic
    Automobile(s): 2010 STS 3.6 AWD 1SB Black Cherry
    Oct 2011
    P. R. of MA.
    55
    356
    Quote Originally Posted by KRSTS View Post
    Interesting that after 61K that the gap has widened, do you have a measurement number?
    I am on the understanding that these platinum plugs are good for 100,000.
    Not to start trouble, but, what octane gas do you use?
    And what does the manual say for octane?
    My 07 CTS 3.6 required 89 octane, by the manual. I would lose 2 mpg if I used 87 octane.
    But my 10 STS 3.6 requires only 87 octane, by the manual. I saw no gain by using 89.
  7. #6
    CadiTamer is offline Cadillac Owners Fanatic
    Automobile(s): 2006 STS 3.6 RWD
    Dec 2013
    22
    117
    My 2006 3.6 STS was getting about 14MPG (i drive nearly 100% city, and it's hard city driving too), and is closer to 17 now that i changed the plugs. Was at 131K when i changed them, and the gap had gotten pretty wide... They were dry, except some oil that had leaked down the spark plug tube on cylinder #5.
  8. #7
    KRSTS Guest
    Quote Originally Posted by daddy_o View Post
    Spec gap is .043 for ACDELCO Platinun Professional #41-990. The ones I took out were at .058 but otherwise normal in every way. I just looked at the box and it says 100,000 Mile limited warranty against defects in design, materials and workmanship. Nothing about longevity. I use Top Tier 87 octane just as the manual recommends, usually Exxon or Shell. Hope this answers your questions daddy_o.
  9. #8
    funk_drum is offline Cadillac Owners Member
    Automobile(s): 2008 STS4
    Jan 2014
    40
    I think the 100,000 mile thing is for the electrode. Not sure how the gap would stay the same over that many miles.
  10. Remove Advertisements
