2008 memory seats and reprograming owner info
Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By Guy.Seminerio
Cadillac STS Forum - 2005 through 2012 Discussion, 2008 memory seats and reprograming owner info in Past Cadillac Vehicle Discussion; I need help in setting my memory for seats and reprograming my name as the new owner. Thanks nick...
    NICK FORSTER is offline Cadillac Owners Member
    Automobile(s): 2008 STS
    Jan 2014
    65
    1
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    Re: 2008 memory seats and reprograming owner info
    Do you have nav?
    Feb 2013
    Whitestone, NY
    28
    3,211
    If you have nav, press config, then vehicle, then personal settings and there are a bunch of options in there you can play with including the greeting.
    Also, while in park, set the seats, wheel, mirror to your liking. Then press config and press AND HOLD the driver 1 button. Wait until you hear it beep a couple of times. Once you're done, this seat setting is saved. Now if someone changes something, you get in the car, press config, press (not hold) driver one and your settings will be recalled.
    In the personal settings I mentioned above you can turn off the driver position recall completely. I don't use an exit position and driving position. I just leave it in one position permanently so I can't comment on how to set that up.
    funk_drum likes this.
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    The seat exit setting works a bit differently after the Nav firmware upgrade but it is definitely worth it.
    Its all in the Nav supplement to the Owners manual. It's available in pdf for free. The like is in the Sticky at the top of the forum. The book(s) are available from Helm Inc.
  7. Remove Advertisements
