Quality of replacement inside door handles
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 23
Like Tree1Likes
Cadillac STS Forum - 2005 through 2012 Discussion, Quality of replacement inside door handles in Past Cadillac Vehicle Discussion; I have two STS's and both have inside door handles that are sharp with peeling chrome. Are the replacement handles ...
    hiltonny is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Apr 2008
    171
    I have two STS's and both have inside door handles that are sharp with peeling chrome. Are the replacement handles any better quality and about what do they cost?
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Nope
    Same handle
    curtc's Avatar
    curtc is online now Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,046
    Re: Quality of replacement inside door handles
    I've heard the replacements have the same issue unfortunately. My driver side starting peeling as well. I just took some aluminum repair tape and cut a small piece to fit over the cracked area. It's been holding up just fine for quite a while and you hardly even notice it.
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,241
    The aluminum tape that has a peel-off backing can be shaped and formed to cover the sharp edge very nicely and is barely noticeable.
    skippydts's Avatar
    skippydts is offline Cadillac Owners Fanatic
    Automobile(s): 2008 STS AWD - Black inside and out
    Apr 2008
    52
    285
    Wow. Amazing. i was just searching for interior door handles. I just bought a 2008 with flaking chrome. I can't find a video on how to replace them. Does the panel need to be removed, or can I get to it without removing the panel? I haven't looked at it yet. It is too darn cold here right now to mess with plastic peices.. One thing about my 03 DTS, is that they were metal handles.. If my initial search was right, the handles are about $40.00 ea.
    ddalder's Avatar
    ddalder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-4 N* 1SG, 08 DTS Luxury II, 04 Bonneville GXP N*
    Aug 2008
    Canada
    2,816
    The door panel must come off. The GM parts listing will tell you that there are two speed nuts required as well. Don't buy them, they are too small and can't be threaded down over the plastic post that secures the handle in place. When the door panels are built in the factory, the plastic posts are melted down (you'll see what I mean when you take off the panel). Either find a way to melt the posts (soldering gun with the correct tip - not a soldering iron) or go to the auto parts store and try to get self-threading speed nuts that are the correct size. I'll try and post pics later from when I did mine.
    FWIW, it isn't just the STS that has this problem. We have a fleet of Yukon's and Tahoe's that all have the very same issue.
    nwjones18 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS V8
    Feb 2013
    Georgia
    30
    202
    Mine are peeling the same way..
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,241
    The aluminum tape is a permanent repair. Replacement handles are going to peel just like the originals.
    skippydts's Avatar
    Apr 2008
    52
    285
    Don't you feel the creases in the aluminum tape? How do you wrap the end of it? maybe I will just leave it alone...
    I just purchased this vehicle and have been reading posts on here. Is this typical of all car forums? Always seeing the bad stuff? I am getting depressed reading the posts. I need to stay away. I really like driving it, and it looks great.
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Quote Originally Posted by skippydts
    Most people don't come on to praise, they come to bitch. Welcome to society.
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,241
    Quote Originally Posted by skippydts View Post
    The only sharp corner on mine was across the top. I cut a piece of tape about 3/4" wide. I rounded the lower corners, stuck down the lower edge first and ironed the rest of it down working towards the top, over the top and down the other side using a round piece of steel. I trimmed the excess on the back side. It took about 5 minutes total.
    Midnight is online now Cadillac Owners Fanatic
    Automobile(s): 2005 STS 1SG
    Nov 2009
    Baltimore
    41
    309
    Man, it's a shame that 1, they could mess up chrome plating, I mean, I thought we had that figured out in the 50's? and 2, knowing there was an issue they didn't fix the replacements.
    One of mine (driver's) is peeling and very sharp, I even cut myself once, but I'm too lazy to mess with it. Now that that part of my hand is healed over and scarred, I don't have any issues any more.
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,046
    What chrome plating? It's a plastic handle covered in more shiny plastic, no chrome whatsoever.
    Ludacrisvp likes this.
  16. #14
    ddgm is offline Cadillac Owners Fanatic
    Jun 2009
    Hamilton, ON & Fort Myers, FL
    270
    Quote Originally Posted by Midnight View Post
    Wow! Mine is peeling and sharp too. I often wondered if anyone got cut, it would be safety issue and GM would have to do something about it.
    What does the membership think?
    Doug
  17. #15
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,046
    I would agree that it could be a potential saftey concern, but not a big enough one for GM to really care. Granted I wouldn't mind seeing a recall for a door handle but I'd say that's a bit of a pipe dream for all of us.
  18. Remove Advertisements
