06 sts oil pan leak
Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By Neutrocuted
Cadillac STS Forum - 2005 through 2012 Discussion, 06 sts oil pan leak in Past Cadillac Vehicle Discussion; hey guys ive only had my sts for a few months it currently has 102xxx miles and i noticed a ...
    JT_alpha is offline Cadillac Owners Member
    Automobile(s): 06 sts 4.6 lh2
    Jan 2014
    27
    8
    06 sts oil pan leak
    hey guys ive only had my sts for a few months it currently has 102xxx miles and i noticed a dot of oil on my drive way when i looked under and sure enough there is oil dripping from my pan so i figure must be the oil pan gasket. im just here to ask if there's any surprises i should be ready for before i pull it and it looks like it goes over the rack and pinion all the way to the trans. is this going to be a problem or should it slip Right out?
    KRSTS Guest
    Re: 06 sts oil pan leak
    Make sure its the oil pan before pulling it. Could be coming from somewhere else.
    Jan 2014
    27
    8
    Well I don't see any oil coming from above it starts at the oil pan I was just reading the older model Seville had to pull the whole engine to change the gasket and was wondering if its the same case for the 06 4.6 v-8 .
    CadiTamer is offline Cadillac Owners Fanatic
    Automobile(s): 2006 STS 3.6 RWD
    Dec 2013
    22
    117
    It doesn't look like the engine has to come out, but there seems to be a good bit of stuff that has to come out... Front cover has to come off, intermediate steering shaft, and the lower engine mount has to be disconnected. Can't tell, but the engine may have to be lifted a bit to get it out.
    This is all off of Alldata for the V6, so in practice with the N*, it is probably different.
    Jan 2014
    27
    8
    I don't want to get in there then find out I can't do it myself you know
    ddgm is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS
    Jun 2009
    Hamilton, ON & Fort Myers, FL
    271
    First, I would clean the area really well, then look for the source of the leak. I would also get a quote on replacing the oil pan gasket if that is what it turns out to be.
    The more information you have, the easier it will be to decide your best course of action.
    Doug
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,548
    Clean it up really well anywhere you see oil. Then get it changed out with some UV dye additive and you or the dealer with a uv light will be able to spot where the actual leak is from if there is one. Perhaps someone was a bit messy last time the oil was changed and its not really leaking.
    Jan 2014
    27
    8
    OK thanks guys I figured I would ask here before going to a shop
    jaime51 is offline Cadillac Owners Member
    Automobile(s): Red 2005 STS AWD V8 Fully Loaded
    Jan 2012
    North New Jersey
    25
    4
    I recently noticed that my 2005 Northstar had oil that was leaking from the rear portion of the oil pan and I also assumed that it was the oil pan gasket. After bringing it in to the dealer to get it checked out, it turned out being 2 seals that were leaking from my front differential. Your best bet is to have someone diagnose your problem to save yourself some frustration.
    Neutrocuted's Avatar
    Neutrocuted is offline Cadillac Owners Fanatic
    May 2010
    460
    Direct from ALLDATAdiy for 2006 STS 4.6
    1. Install the engine support fixture.
    2. Drain the engine oil.
    3. Remove the front frame.
    4. Remove the front differential carrier, if equipped.
    5. Disconnect the electrical connector from the engine oil level sensor.
    6. Remove the engine oil level sensor from the oil pan.
    7. Remove the oil pan bolts.
    8. Important: The oil pan gasket is reusable unless damaged. Do not remove the gasket from the oil pan groove unless replacement is required.
    Remove the oil pan.
    1. Clean and inspect the oil pan. Refer to Oil Pan Cleaning and Inspection .
    Installation Procedure
    1. If required, install a new oil pan seal using the following procedure:
    1. Clean any residual oil from the seal groove.
    2. Work the seal into the pan groove in both directions around the pan.
    3. Position the oil pan to the crankcase.
    4. Notice: Refer to Fastener Notice in Service Precautions.
    Install the oil pan bolts. Tighten the bolts in the sequence shown:
    1. First Pass: Tighten the bolts to 15 Nm (11 ft. lbs.) .
    2. Final Pass: Tighten the bolts to 25 Nm (18 ft. lbs.) .
    3. Install the engine oil level sensor into the oil pan.
      • Tighten the sensor to 10 Nm (89 inch lbs.) .
    4. Connect the electrical connector to the engine oil level sensor.
    5. Install the front differential carrier, if equipped.
    6. Install the front frame.
    7. Fill the engine oil.
    8. Remove the engine support fixture.
    9. Inspect for oil leaks after engine start up.
    I would try re-torquing the bolts to see if that's the issue. PM me if you'd like to see the sequence pattern.
    Good luck!
    JT_alpha likes this.
    Jan 2014
    27
    8
    Thank you bro I really appreciate it
  14. Remove Advertisements
