2005 STS No Crank/No Start
Results 1 to 10 of 10
Cadillac STS Forum - 2005 through 2012 Discussion, 2005 STS No Crank/No Start in Past Cadillac Vehicle Discussion; got a 2005 sts with northstar engine I drove it home from work everything worked fine next morning went to ...
    mikera is offline Cadillac Owners Member
    Jan 2014
    got a 2005 sts with northstar engine I drove it home from work everything worked fine next morning went to start it hit the brakes pushed the button all the dashboard lights turned off everything then 15 seconds later it came back on when I tried to scan it for codes there is no communication with the pcm but my scanner can communicate with the tcm and all the other moduals starter is not bad I jumped it from the relay box and it cranks the engine but still no start any one else have this kind of problem
    C&C's Avatar
    C&C
    C&C is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac XT5 (2017)
    Feb 2008
    Mount Pleasant, SC
    66
    1,907
    Re: 2005 STS No Crank/No Start
    Could be lots of things, but with all start problems, first step is to verify a good battery and battery terminal attachments (for tightness).
    Jan 2014
    battery is brand new from dealer terminals are on good and tight
  5. #4
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    Don't rule out the battery. Have it tested. I've experienced personally/heard stories of defective batteries many times. Has the car been driven since the battery was replaced?
  6. #5
    JT_alpha is offline Cadillac Owners Member
    Automobile(s): 06 sts 4.6 lh2
    Jan 2014
    27
    8
    ive had this problem before when i tried to scan for codes too try disconecting the battery for about a minute and connect back this will reset the ecu and then try again it should crank
  7. #6
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Facing that symptom, I would also first suspect the battery.
  8. #7
    Roger O'Dell is offline Cadillac Owners Member
    Automobile(s): 2005 sts2007 xlr v1941,1947,1948 sedenettes,1957 seville,195
    Nov 2009
    Canyon Lake, Ca
    70
    26
    I had a similar problem last week, stopped for lunch, got back in the car, starter clicked but didn't turn the eng over. As time went on I noticed a msg "THEFT ATTEMPT START DEACTIVATED" or something. But it appeared to me to be a weak battery,however the acc worked fine radio etc. I called the auto club to replace the Battery. They came out and did a test, said battery was ok. I had it towed, was going to the dealer but by the time I got in the Area they were closed. I took it home jumped the Batt next morning, took it to the dealer, they tested and said batt had a weak cell. I had them replace the Batt in my 2005 sts 4.6 as well as the key thob Batt. Worked ok this week. Roger
  9. #8
    keith721 is offline Cadillac Owners Member
    Automobile(s): 2010 STS 3.6L V6
    Sep 2005
    35
    I've purchased new batteries before that had defective cells and another that was shorted dead and refused to charge at all. Just because it's new doesn't mean it's not bad in some way.
  10. #9
    TimmyC is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V and 2007 STS-V The Murdalac
    Feb 2009
    1/2 hr S of Grand Rapids, MI
    37
    1,892
    Did this get resolved? Non communication problems are usually power to the module in question or data wire continuity.
  11. #10
    daddy_o's Avatar
    daddy_o is offline Cadillac Owners Fanatic
    Automobile(s): 2010 STS 3.6 AWD 1SB Black Cherry
    Oct 2011
    P. R. of MA.
    55
    356
    Quote Originally Posted by TimmyC View Post
    I too, ask, did it get resolved.
    Folks, especially new folks, don't abandon us here just because the problem is fixed,
    This is a site to help and solve, every time you post with an idea or solution, it helps all of us.
    These cars can be like girls, always posing Q's with no solutions.
    (with apologies to super moderator Jesda)
  12. Remove Advertisements
