Technical Issue
Results 1 to 8 of 8
Cadillac STS Forum - 2005 through 2012 Discussion, Technical Issue in Past Cadillac Vehicle Discussion; Hi Guys, I receives two messages "ENGINE POWER REDUCED" and "SERVICE STABILITY SYS" with the "Traction Control System (TCS)" warning ...
    aqari is offline Cadillac Owners Member
    Automobile(s): STS
    Dec 2013
    12
    Technical Issue
    Hi Guys,
    I receives two messages "ENGINE POWER REDUCED" and "SERVICE STABILITY SYS" with the "Traction Control System (TCS)" warning light appearing on the instrument panel and the car stops accelrating for more than 25km/h.
    My car is STS 2009 LLT 3.6L V6
    Please help !
    Asim
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    Re: Technical Issue
    If you're stuck somewhere you can try the battery disconnect, touch cables together for about 30 secs, and reconnect and see if that gets you where you need to go until someone else on here diagnoses what you have going on.
    Automobile(s): STS
    Dec 2013
    12
    Re: Technical Issue
    thanks for your reply.
    actualy, it's happening every once in a while and when I turn off the car and run it again, it works fine for couple of minutes.
    a tech said it's a problem in the fuel pedal and fixed it, but the issue still there.
    B1n2fra's Avatar
    B1n2fra is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 1SG STS v8 awd
    Nov 2011
    Chicago
    36
    502
    Sounds like a bad wheel hub connector. Or a bad wheel hub itself. I had a bad wheel hub connector on my previous car and it would be Fine every time I restarted the car then randomly throw the message when it felt like it. I would have to get under the car then wiggle it sometimes to make it go away.
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,674
    Re: Technical Issue
    Hello!
    I am truly sorry to hear of this concern you are experiencing with your vehicle. If you would like to send us a private message with your location, we would be happy to get you in contact with the proper department to assist. Thank you!
    Jessica (assisting Laura)
    Cadillac Customer Care
    Quote Originally Posted by aqari View Post
    Hi Guys,
    Please help !
    Asim
    Automobile(s): STS
    Dec 2013
    12
    Re: Technical Issue
    Quote Originally Posted by B1n2fra View Post
    Many thanks for the advice; will chekc this issue with the mechanic
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    Re: Technical Issue
    Also check that the fuse block is secured tightly and there are no loose bolts ... we've seen similar symptoms before on other cars that turned out to be loose grounds or loose connections on the fuse block
    Automobile(s): STS
    Dec 2013
    12
    Re: Technical Issue
    Thanks, will check this out as well.
    But one more thing, and wondering if it's related; I hear like a drumming sound while accelerating and feel like the the car exhaster is strangulated. Is it possible that might cause the problem!
  11. Remove Advertisements
