2003 sts v8- no heat
Results 1 to 4 of 4
Cadillac STS Forum - 2005 through 2012 Discussion, 2003 sts v8- no heat in Past Cadillac Vehicle Discussion; Ok my HEAT, defrost A/C is on but no air blows from the vent. I was told to "bang"under the ...
    CTgirl22 is offline Cadillac Owners Member
    Automobile(s): 2003 Seville
    Dec 2013
    1
    Ok my HEAT, defrost A/C is on but no air blows from the vent. I was told to "bang"under the glove box which worked for the last several weeks. Now that doesn't even work HELP!!!!!
    I checked coolant it was low....damn near none.
    Could it be the blower? Is this something I can do myself?
    B4 I take it to a $$$mechanic and they charge me for a right arm
    and my 1st born, I would like to have a clear idea of what my options are.
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Quote Originally Posted by CTgirl22
    2 things
    You have a SEVILLE STS not a STS. Wrong forum
    Without coolant you will have no heat. If your blower motor wasn't working you wouldn't have any air blowing out of any of the vents at all. Hitting the dash would only work if you had a sticky blend door.
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,046
    Re: 2003 sts v8- no heat
    Find out where the coolant is going, that's your first task. Like said above, with no coolant comes no heat. I would get two things, 1) a coolant system pressure kit, this will aid in determining where the leak is, hopefully it's external. 2) A block test kit, you'll use this to determine if there are exhaust gases in the coolant system, this will rule out a HG leak if it doesn't come back as positive.
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Curt has the right approach. Until you KNOW the source of that coolant leak, a blend door issue is the least of your worries. By 2003, the Seville's HG issues were largely corrected (we has a '98). They were very nice cars with great lines & performance (for a FWD).
    Do check out the Seville forum. Members there will be able to guide you on the tasks you can do yourself, save some buck at an independent shop or need the specialized knowledge or tools of a dealer.
  7. Remove Advertisements
