Headlight bulb replacement
Results 1 to 10 of 10
Cadillac STS Forum - 2005 through 2012 Discussion, Headlight bulb replacement in Past Cadillac Vehicle Discussion; Yesterday I noticed that the small "bullet" style light in one of my headlights isn't working. Anybody know what it's ...
    3859c1's Avatar
    3859c1 is offline Cadillac Owners Member
    Automobile(s): 2006 STS
    Nov 2013
    Dewitt, IA
    39
    Yesterday I noticed that the small "bullet" style light in one of my headlights isn't working. Anybody know what it's calked. Is it the daytime running lamp or something. I don't really want to pull the bumper off myself. How much does is cost to have done at a dealership? Thanks!
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,482
    It's called a "city light" but for some reason people here call it a "peanut light".
    Replacement calls for removal of the front bumper and wheels and liners. So at a dealer will be expensive as they will do it by the book.
    Some of us will let them burn out and never replace them. Some try LEDs but have issues with some of them failing due to cheap replacements. Others that replace them aren't able to get the ones that are tinted to match the HIDs.
    Sent from AutoGuide.com App
    lt4obsessed is offline Cadillac Owners Member
    Automobile(s): 2006 STS V6
    Nov 2013
    3
    Re: Headlight bulb replacement
    I have one out also, so my plan is to wait until one of the headlamps burn out, then replace them all at the same time.
  5. #4
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    That probably won't happen for years.
    Oh crap sorry that's only if you have HIDs.
  6. #5
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,482
    Quote Originally Posted by Guy.Seminerio View Post
    Well at the rate my highbeams go on and off i'll bet its going to be soon.
  7. #6
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,028
    I let both of those stupid bulbs go out and I don't think I'll ever replace them...In my CTS you could get to them from the wheel well, there was a screw on cap on the bottom of the headlight housing. I refuse to take off my bumper for those little bulbs. If/when an HID or high beam goes out I'll think about it, and LEDs will be going in when that occurs.
  8. #7
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,482
    Quote Originally Posted by curtc View Post
    I'm doing the same here. LEDs will be obtained if / when something more important goes out in the headlight (or if the time comes when I proactively replace the HIDs with the Osram 66144 CBIs which should be more powerful than the OEM phillips lamps).
  9. #8
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Technically if your county has inspection testing your car will fail for having those lamps out. Also they can be reached through the hood by removing the air box on the drivers side and fuse box on the passenger side.
    I had LEDs and after less than a year both started flickering, I replaced with a set of "blue" 194s which the ATS uses in the dome/map lights. Very close match to the HIDs and been in for over a year without issue.
    Also the heat given off by them helps dissipate any condensation in the lamps MUCH better than the LEDs did.
  10. #9
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,028
    No inpsections whatsoever here in MN so that isn't a problem at all. I think I'd rather drop the bumper than remove the air/fuse box, from what I've seen the bumper isn't terribly difficult to remove, just not doing in the dead of winter with no heated garage.
  11. #10
    sub613's Avatar
    sub613 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 STS 1SF N* RWD NAV F55
    Mar 2009
    NC for Now, Florida SOON
    704
    CoolRe: Headlight bulb replacement
    Spent the money to get the replacement bulbs from Cadillac, it was blue tinted, I wanted them to
    retain the same color as the Headlights, I replaced one, and almost immediately the other one
    went out,So i "HAD" to replace them both, however, the color really dis-appointed me greatly,
    they were very low on the kelvin scale and not near the 5000 K, I wanted.
    They are almost incandescent in color.I am NOT going to go thru that again !
    BTW they cost $ 9.89 each, including tax, I have an 06, So when I replaced them, they both
    leaked water, I had to go into the covers , AGAIN, this time i used Permatex, NON HARDENING.
    on both sides of the gasket, YES, it's messy, but necessary to waterproof the covers.
    Please do NOT think the gasket will seal, by itself, it won't !
    They have NOT leaked since.
    Happy Motoring.
  12. Remove Advertisements
