Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Thread: ABS+Stability+Traction issue
    No Quarter's Avatar
    No Quarter is offline Cadillac Owners Fanatic
    Automobile(s): 2009 CTS-V, 2006 STS 3.6
    Sep 2013
    Denmark
    144
    A month ago I got a warning while braking semi-hard, Service Stability Sys and Service Brake Assist. Nothing could be felt, only the warning lamps glowing at me. Happened again a few trips later. Gradually became more frequent and needed less hard braking to come on. Lately it'll turn on after a few seconds after start whether I'm braking or not.
    Annoying but I could drive on. Well tonight something new happened, when braking normally the pedal pulsates a little and with high frequency just before I stop. So if braking from 50 mph to 0 mph in a normal fashion, at 5 mph the ABS (which I assume it is) starts without being needed.
    Anything I can do before driving to the money hungry dealer? Testing, changing most likely components? Can I drive it?!
    Any suggestion is welcome.
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Wheel bearing or steering wheel postion sensor is my bet. The cheapest thing would be take it to the dealer for a proper diagnosis. You can choose to throw parts at it until you hopefully fix it or buy a tech 2 and scan it yourself however both of those will be much higher than the $80 diagnostic fee. It's a Cadillac not a Honda which any jiffy lube can diagnose an issue with.
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,061
    Re: ABS+Stability+Traction issue
    With those messages present you should be able to get it scanned at a local parts store, as long as their scanner can read more than just PCM codes. I also suspect a wheel speed sensor (wheel bearing) or steering wheel position sensor, the code(s) will tell the full story though.
  5. #4
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Quote Originally Posted by curtc
    I have never seen a parts store with ascanner capable of listing Cxxxx abs chassis codes....
  6. #5
    dkozloski's Avatar
    dkozloski is online now Cadillac Owners 10000+ Posts
    Jul 2004
    Fairbanks, Ak
    28,287
    If your car happens to be one of those with what is known as "ABS Assisted" brakes, a rather peculiar power assist system, you are about to experience having no brakes at all.
    Don't mess with Binky Bear!
  7. #6
    Mar 2012
    columbus ohio
    382
    Warped rotors could be a problem. Danny
  8. #7
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Warped rotors have NOTHING to do with ABS and stability light coming on upon initial start up not to mention warped rotors are completely fictitious...
  9. #8
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
  10. #9
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,061
    Quote Originally Posted by 1BadCadSTS View Post
    I have. Friend of mine worked at Advance Auto a few years back, whatever he used read P, C, and B codes.
  11. #10
    No Quarter's Avatar
    Sep 2013
    Denmark
    144
    Got lucky I think, the local garage I sometimes use when I have more money than time(), they could read the fault codes on their laptop. Rear left ABS sensor. So I need a new bearing/hub. They are priced very very differently, OEM is about 10x as expensive at the China part. I've always used the cheapest part available for my Jeep Grand Cherokee, including hubs, worked fine. Does anybody have experience with these cheap hubs?
  12. #11
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Sure, and youll be replacing it again shortly.
    Moog is the ONLY one other than Delco I would put on my car. Cheap parts are cheap for a reason.
  13. #12
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,061
    I've had good luck with Timken and SKF bearings, I've also used many Moog parts in the past as well, no bearings though.
  14. #13
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Timken I would use too.
    However using the cheapest part available isn't the best course as the op is assuming he can get away with.
  15. #14
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,061
    Wheel bearings are like tires and beds, you get what you pay for...Cheap out and you'll be doing it again soon and replacing a wheel bearing isn't exactly my favorite thing to do.
  16. #15
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Agreed!
  • You may not post replies
