Backup Camera Interface - Page 2
Page 2 of 7 FirstFirst 1234567 LastLast
Results 16 to 30 of 103
Like Tree9Likes
Cadillac STS Forum - 2005 through 2012 Discussion, Backup Camera Interface in Past Cadillac Vehicle Discussion; ...could be interesting...if this will work with the export nav/radio, too...? (hmm...should also source the china cadillac sls backup camera... ...
  1. #16
    PontiacV8's Avatar
    PontiacV8 is offline Cadillac Owners Fanatic
    Automobile(s): 2015 Camaro 2SS, Sold: 2006 STS (EXP) 1997 Seville STS (EXP)
    Dec 2006
    Germany / Nordhorn
    423
    Re: Backup Camera Interface
    ...could be interesting...if this will work with the export nav/radio, too...? (hmm...should also source the china cadillac sls backup camera... )
  2. #17
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,536
    Quote Originally Posted by PontiacV8 View Post
    Which is very readily available on aliexpress.com and the only clean way to add the camera making it feel very factory.
    This would / could also make it technically possible to integrate a FLIR camera (aka nightvision) and have it display on the nav screen while moving forward if you setup a manual trigger method (which makes some assumptions about it's inherent design)
  3. #18
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Already ordered one!
    Quote Originally Posted by Ludacrisvp View Post
    why cant you just use the AUX input for that?
    Technically we can for the reverse cam but i prefer for it to default to it automatically when putting in reverse. To install night-vision you should just run the AUX so you can have access to it any time...
  5. #19
    targetSTS is offline Cadillac Owners Fanatic
    Automobile(s): 2005 cadillac STS AWD 1SG
    Mar 2011
    34
    391
    yeah it possible to buy the camera, but it doesn't fit STS directly, cause they change the hole size in the trunk where backup camera and license plate lights located. So to install it same way as OEM you need to buy SLS trunk lid too
  6. #20
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Quote Originally Posted by targetSTS
    09 should fit. The 10+ is different more round mounting.
    2009
    http://www.aliexpress.com/item/Free-...793266787.html
    2010
    http://www.aliexpress.com/item/car-c...441255337.html
  7. #21
    Mar 2011
    34
    391
    Oh no
    both are 5$ crap. not oem. Even SLS haven't had oem backup camera until 2010
    I'm talking about oem camera.
  8. #22
    PontiacV8's Avatar
    Dec 2006
    Germany / Nordhorn
    423
    Quote Originally Posted by targetSTS View Post
    ...really...?...a complete trunk lid? ...if...this will be...ouch... ...ok...no OEM install...
    Quote Originally Posted by 1BadCadSTS View Post
    ...yeah...I know...
    ...but...the "2010" part as shown is not just another design...this is the "center" part, for the trunk switch/touch pad, not the lh license plate lamp/housing...(for SLS with backup camera they changed and "shortened" the switch to place the camera)
    ...so you will also need an original 2010-up SLS trunk switch/touch pad to use this chromed "center" part with camera...alieexpress only sells the cromed part with camera...it doesn't contain the trunk switch...
    ...the part shown in the first link is the lh license plate light, which might be the easier install...unfortunately it is black, not chromed...
  9. #23
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Oh no
    OEM is $ due to increased functionality. It will not show parking grid with lines and turn with the wheel like newer cars cuz we aren't programmed for it.
    For $20 it will be fine. I bought it and honestly who would notice the lack of chrome vs the other trim. I bought one ill post up how it looks when I'm done.
  10. #24
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,536
    This is assuming you also have a lockpick installed...
    I haven't had my lockpick or audio input device (iSimple audio gateway) installed for months due to the dealer's blaming them for my speed limited to 120mph ongoing issue.
    If this device will use the LAN to determine if it is in reverse then that would be ideal but I feel that it would need a trigger wire of some kind like is used on aftermarket backup camera additions that basically turn on when the backup lamps are on.
    Sent from AutoGuide.com App
  11. #25
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Likely it will use a relay trigger. Reverse lights activate wire which trips relay which forces nav to camera mode.
  12. #26
    Mar 2011
    34
    391
    I tested some of them, working so-so, better than nothing, but it has cheap matrix and lens as result mediocre image quality.
    oem camera should be much better. Going to try it later.....not now
  13. #27
    raiders4u2nv's Avatar
    raiders4u2nv is offline Cadillac Owners Member
    Automobile(s): 2007 STS V Silver/ 2007 Escalade Silver/ 94 Corvette vert
    Oct 2011
    82
    Plasti dip all three and they will look good.
  14. #28
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    So when you shift from drive to park and vice versa and your reverse lights cut on for that split second, the nav will be forced into backup camera mode? Hopefully there's some kind of a delay built into it.
  15. #29
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,536
    Quote Originally Posted by Guy.Seminerio View Post
    You would either have to design the delay into the unit or have a time delay relay. Ideally it would keep the backup camera active for about 5 seconds after you change gears too like oem does so you can move forward and back without dealing with waiting for display lag.
    ^^^ I HATE THIS APP!!!!!
    You cannot disable this signature even using the PAID app.
    Tapatalk was so much better.
    Guy.Seminerio likes this.
  16. #30
    Feb 2013
    Whitestone, NY
    28
    3,211
    Yep forgot about a delay to keep it on when it's put back into drive.
    I just use safari on my iPhone when doing the forums.
  17. Remove Advertisements
