MID/TID results
Results 1 to 4 of 4
Cadillac STS Forum - 2005 through 2012 Discussion, MID/TID results in Past Cadillac Vehicle Discussion; I have had problems with My 05 STS with N* engine. I was going through the Mode 6 tests and ...
    ABQDon is offline Cadillac Owners Member
    Automobile(s): 2005 STS
    Feb 2010
    Albuquerque, NM
    56
    11
    MID/TID results
    I have had problems with My 05 STS with N* engine. I was going through the Mode 6 tests and have the following two failures:
    MID:$8f TID:$76
    Max: 20,503 Min: 52,352
    Test result value: 3
    FAIL
    MID:$9e TID:$57
    Max: 57.345 Min: 52.415
    Test result value: 0.003
    FAIL
    Is there any way to find out what these tests are? All other tests passed.
    Thanks in advance for your help.
    Feb 2010
    Albuquerque, NM
    56
    11
    Re: MID/TID results
    Additional information:
    Ran tests a couple of days later and I now have a different (but similar) error being reported instead of that which was described above:
    MID:$0f TID:$76
    - O2 Bank 4 Sensor 3
    Max: 20,500 Min: 52,352
    FAIL
    MID:$1e TID:$57
    Max: 57.344 Min: 52.415
    FAIL
    Now I have several observations:
    1) from the information provided above, it appears that this may be very similar to the original error (same min/max and results), but this time there was a description attached.
    2) The TIDs are the same between the two samples but not the MID (first was $8f/$9e, second was $0f/$1e). hmmm. suspicious?
    3) the original MID/TID numbers did not appear in the mode 6 report.
    4) my analyzer has a feature where I can select and monitor an O2 sensor, but it does not give the option for anything beyond Bank 2. How many 02 banks/sensors are there?
    dkozloski's Avatar
    dkozloski is online now Cadillac Owners 10000+ Posts
    Jul 2004
    Fairbanks, Ak
    28,316
    Re: MID/TID results
    Two banks with two sensors each.
    Don't mess with Binky Bear!
    Feb 2010
    Albuquerque, NM
    56
    11
    Re: MID/TID results
    Obviously a periodical test (changes with each drive cycle). Below is the latest. Wish I could figure out what sensor this is so I can see if it's the root of the problems that I've been having.
    MID:$1e TID:$57
    FAIL
    MID:$21 TID:$a0
    - Catalyst Monitor Bank 1
    Max: 0.99942 Min: 0
    Test result value: 0.8745
    PASS
    MID:$22 TID:$a0
    - Catalyst Monitor Bank 2
    Max: 0.99942 Min: 0
    Test result value: 0.59341
    PASS
    MID:$2f TID:$76
    Max: 20,640 Min: 52,352
    FAIL
  7. Remove Advertisements
