2005 STS with AWD and MRC Shock Replacement
Results 1 to 13 of 13
Cadillac STS Forum - 2005 through 2012 Discussion, 2005 STS with AWD and MRC Shock Replacement in Past Cadillac Vehicle Discussion; I thought I'd start a new thread as there isn't much on this that I could find... My shocks are ...
    stevenriz is offline Cadillac Owners Enthusiast
    Automobile(s): 2008 STS4 V8 1SG Platinum Edition
    Apr 2009
    Central MA
    49
    548
    My shocks are leaking, more in the rear. I see drops all over the wheels. Are the rears difficult for an amateur to install? What is the procedure? Jack it up enough to drop the wheels just enough to take pressure off the shock itself and then R&R... ? Does anyone know torque specifications? I will ask a friend that works at the local Ford dealer and hope he is able to assist...
    Any help would be appreciated. I need to determine if this heap is worth keeping up. Barely a mark on it so I'd like to think so but don't want it to become a money pit more than it already is...
    thanks all!
    Steve
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,063
    Re: 2005 STS with AWD and MRC Shock Replacement
    An 8 year old $60,000 luxury car won't be cheap to maintain unfortunately. I dumped thousands into my 2001 STS in the 5+ years I owned her from 2006-2011, sold her with 233k on the clock.
    If you like the car she's worth keeping up on, that is, IF you can afford it.
    Hopefully someone will chime in with some answers for you, I don't have any experience replacing shocks/struts so not sure what is all involved.
    Apr 2009
    Central MA
    49
    548
    Hey all. Here is an update... The dealer just told me all 4 shocks are leaking and the compressor is gone because the air bags (I don't know what you call them) do not hold air anymore. I asked them if the compressor and the air bags are a single unit. She wasn't sure if the MRC shocks had the air reservoir within them or the air suspension was a separate part. Does anyone know here? I will know more what I need when the dealer calls me back and what parts I need. I can then make a better decision on what to do... Repair or replace. I am also thinking that if I replace, I will just get maybe a 2013 LTZ Lumina (I know I know, no comparison WHATSOEVER but it is a roomy comfy car) and pay off a few bills then when debt free, get another Caddy...
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,063
    They still make Lumina's, do you mean Impala? Cannot repair leaking MRC shocks, they need to be replaced....As far as the self leveling in the rear is concerned, the air bladders are built into the rear shocks and the compressor is a separate piece.
    Apr 2009
    Central MA
    49
    548
    yes I meant Impala sorry. I had a 1998 Lumina LTZ and was reminising haha...
    That is good, well, better news the shock actually contains the air bladders within. Question. Would I get a message saying the compressor or something is bad? I hear is, well I used to hear it each time I started the car. I will check next time I start and walk to the back and wait. It used to run for a few seconds.
    Thanks CURTC
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,063
    You won't get a message for leaky air bladders, I would think you'd get a trouble code for a compressor that's shot though. It should run after you start the car for a few seconds. You can also test it by starting the car and then opening the trunk and sitting on the lip. After a bit the compressor should kick in and raise the rear to compensate for the added weight. If you feel it start to go back down the bladder's are most definitely leaking.
    Apr 2009
    Central MA
    49
    548
    will do. thanks man!
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    I'm thinking replacing the shocks is going to be a lot cheaper than buying a new car.
    What if the car doesn't raise up in the first place? That could be a bigger leak. Bad compressor too, but we're assuming the car would tell him if the compressor was bad.
    Apr 2009
    Central MA
    49
    548
    good point Guy. Just spoke with the dealer. $5320 for 4 shocks, compressor and alignment. I will weigh that with a local repair guy if I buy the parts from Rippy or Rock against the Impala... UGH!
    B1n2fra's Avatar
    B1n2fra is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 1SG STS v8 awd
    Nov 2011
    Chicago
    36
    502
    Rear shocks are easy to replace. I've replace mine in about thirty mins in my drive way. Two screws in the trunk and one big long bolt at the bottom. Remove the air hose and off it comes
    Apr 2009
    Central MA
    49
    548
    hm that's pretty cool. Do you have to jack the car up or anything or just do it on the ground? I suppose jack it up enough to get underneath. I also need a compressor. Is that easy to get to?
    B1n2fra's Avatar
    Nov 2011
    Chicago
    36
    502
    You can do it on the ground but jacking it up and taking the tire off just makes it easier. Plus when removing the shock of the car is on the ground you would have to compress the shock a little more to remove it and to compress it takes a lot of strength. So like I said jacking it up makes it easier
    turnne is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac STS
    Oct 2007
    Indianapolis Indiana
    53
    1,209
    Quote Originally Posted by stevenriz View Post
    YIKES!!
    how many miles are on the car?
    I have a 2005 V8 AWD 1SG as well...and I think I might want to have an exit strategy for it if there is a general mileage point where this is typical
    Warren
  16. Remove Advertisements
