Results 1 to 4 of 4
Thread: STS 2007 Headlight problem !!
    ahmed1990 is offline Cadillac Owners Member
    Automobile(s): sts
    Oct 2013
    26
    10
    Hello,
    The headlight on he driver side won't work at all , also its a lil bit foggy. I have asked to replace it and they cost too much.
    should i replace the hole kit or just buy a light and replace it ?
    is there anyway i can fix it instead of paying that much. I live in Texas , so please if anyone can tell me another solution of doing it.
    thanks so much
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    Re: STS 2007 Headlight problem !!
    I'm guessing you're talking about HIDs? Either way, you should solve the condensation problem before changing the light. Google search "cadillacforums sts headlight condensation". There are so many threads about how to solve this issue. Once that's done, change your halogen bulb or hid bulb.. Whichever we're talking about. If HID, and changing the bulb doesn't work, change the ballast. I would say it is not normal for HIDs to have gone out on your 2007 already so it's definitely related to the condensation if it is in fact HIDs we're talking about.
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,061
    Yeah, if they're HID it's related to the condensation, they should've lasted longer. My 06 still burns the factory D1S bulbs as bright as can be.
  5. #4
    streamofthought is offline Cadillac Owners Member
    Automobile(s): 2007 STS
    Oct 2013
    37
    5
    Both of my headlights went out within about 3 months of each other. I found out the cost of replacement and decided to do it myself. I'm not very handy, so it took a few hours to complete, but it saved me about $200. I watched this video: http://www.youtube.com/watch?v=DzSnd50oKNw and it explained exactly how to complete it. The tools you'll need are a flat-head screwdriver, a socket wrench, I believe a 10mm socket, a 10mm socket extension. I don't have a good jack, so I couldn't jack up the car, but doing so may help. The flat-head is to pop off the tabs which are a bit of a pain. You'll only need to remove one of the bolts underneath each wheel well, you can slide the bumper off of the other. Hope this helps you too.
  • You may not post replies
