Car seems to hesitate 35-40 mph
Results 1 to 9 of 9
Cadillac STS Forum - 2005 through 2012 Discussion, Car seems to hesitate 35-40 mph in Past Cadillac Vehicle Discussion; Anyone ever have this issue? I have an 05 sts with the north star v8,. If i slowly and accelerate ...
    Hhunter is offline Cadillac Owners Member
    Automobile(s): 2005 STS V8
    Oct 2013
    29
    19
    Anyone ever have this issue? I have an 05 sts with the north star v8,. If i slowly and accelerate and do not push the pedal with force and try to keep the speed constant around 35 mph and then slowly accelerate from that speed it almost hesitates, feels extremely sluggish.. I basically have to push pedal 3/4 way down so that it downshifts and accelerates.. I can't tell if it's a misfire, or a tranny /torque converter issue.. Any easy way to rule out the other? No check engine light.. But when you feel the slight hesitation I usually accelerate thru it.
    STSJr's Avatar
    STSJr is offline Cadillac Owners Fanatic
    Jul 2013
    145
    Hi, I have an 05 STS 4 V8 too. I noticed the same sluggish feeling recently also. I brought my car to the dealer and had the trans fluid checked. It was full and normal. I checked the air filter because I am the second owner and had the car six months. It had the original filter with dirt and leaves. It was also stamped 2005! Wow! I noticed the car has more pick up and doesn't bog anymore. Hopefully this was helpful!
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,039
    Re: Car seems to hesitate 35-40 mph
    I thought there was a TSB out there for something similar to this, I vaguely recall a torque convertor issue being mentioned in this. I've noticed the same thing in my car once in a great while, I just press the gas a bit more and hammer through it
    R/T kota's Avatar
    R/T kota is offline Cadillac Owners Fanatic
    Automobile(s): 2006 STS 4, 67 Firebird, and a pair of SS Impalas
    Jul 2013
    Hamilton Ontario Canada
    46
    112
    Not knowing anything about the tsb for this problem, I can say that it sounds like the t/c is not coming out of lock up under light acceleration.
    Had the same problem with my old dodge truck. It was actually programed in the pcm that way. It was frustrating. high gear at wot it would stay locked up.
    Try tapping the brake pedal lightly when it does that. Brake switch will send a signal to the computer to unlock the tc.
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    There have been various TCM programs over the years for the STS. Now, if you're not under warranty and have an early V8, contact Madtuner and get the TCM and ECM of your own preference.
    Who knows, drive differently for a week and the 'learning' program may adjust to accommodate your preference.
    bigbillsfan is offline Cadillac Owners Member
    Oct 2013
    4
    If this is well known I apologize on advance, but who is Madtuner?
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,039
    Quote Originally Posted by bigbillsfan View Post
    Madtuner is the ONLY known tuner who has cracked the early STS V8 ECM/TCM.
    Ludacrisvp's Avatar
    Ludacrisvp is online now Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,524
    amgqmp1 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS V8 RWD
    Feb 2009
    Aurora, Colorado
    38
    136
    Another workaround for us early 2005 V8 owners is to drive in sport drive (sD). Move the shifter to the right.
  12. Remove Advertisements
