Throttle Body Cleaning
Results 1 to 5 of 5
Cadillac STS Forum - 2005 through 2012 Discussion, Throttle Body Cleaning in Past Cadillac Vehicle Discussion; Just spraying some stuff, or wrapping a rag around my finger and opening the Throttle and wiping it from the ...
    sub613's Avatar
    sub613 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 STS 1SF N* RWD NAV F55
    Mar 2009
    NC for Now, Florida SOON
    704
    CoolThrottle Body Cleaning
    Just spraying some stuff, or wrapping a rag around my finger and opening the Throttle and wiping it from the outside, does NOT seem professional, I have NEVER done one, but have done carburetors. Should I pull it and clean it, will Anti Freeze come out ? Do I need a New gasket, and/or gasket sealer ? Is there help for a Throttle Body dummy ? Thanks
    ddgm is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS
    Jun 2009
    Hamilton, ON & Fort Myers, FL
    270
    Re: Throttle Body Cleaning
    I frequent another forum for my Saab 9-7x, think Envoy or Trailblazer, and the recommendation is to remove the throttle body to clean and disconnect the battery for
    a couple of hours to relearn throttle position. Seems the PCM compensates as the throttle body acquires crud. The throttle body is usually dirtier on the back side. I have no idea if this is the same procedure with our Cadillacs.
    Doug
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    This does make sense. It also makes sense to do it regularly, even if one uses Top Tier fuel and Techron once in a while. If there is any contact between the throttle plate & body at all, deposits seem more likely to act as an abrasive than a lubricant. Once a groove forms, anything short of a new throttle body is a hack.
    There was a point with my 2006 that the throttle seemed a bit touchy when leaving a stop. I'd either launch or leave slower than intended and then have a bit of a surge. After a TB cleaning, I had a lot better control and with the TCM programming in the 1SG, throttle control is big part of driving fun.
    Actually, I'm overdue!
  5. #4
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,174
    I must be the lucky one. My '06 STS AWD V8 has about 60k miles and the throttle body is still as slick and clean as the day the car was delivered. I've had it apart several times for other projects and have never found deposits of any kind in or around the throttle body or intake system.
    Don't mess with Binky Bear!
  6. #5
    sub613's Avatar
    Mar 2009
    704
    So If i Pull it, is there Coolant that runs thru it, Do I need a NEW gasket ?
    Appreciate you help. Thanks.
  7. Remove Advertisements
