Sunroof drains clogged
Results 1 to 10 of 10
Cadillac STS Forum - 2005 through 2012 Discussion, Sunroof drains clogged in Past Cadillac Vehicle Discussion; ...
    Ariel Segarra is offline Cadillac Owners Member
    Automobile(s): STS 2008
    Oct 2013
    6
    QuestionSunroof drains clogged
    Sunroof drain clogged
    My STS have the sunroof drains clogged and I try to clean with thin cable. Now it’s linking under the dash
    How I can fix this problem
    ddalder's Avatar
    ddalder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-4 N* 1SG, 08 DTS Luxury II, 04 Bonneville GXP N*
    Aug 2008
    Canada
    2,800
    Re: Sunroof drains clogged
    This is really bad news. It is not going to be an easy fix at all, but needs to be done. I'll try to find some pictures to post, but I'd put money on the fact that your dash is going to have to come out. This is a lot of work (I've had mine out for other reasons). There is never any guarantee the drain won't separate, but the preferred method is to shoot some compressed air down the line instead of using a wire.
    Which side is leaking?
    There are a couple of possibilities. The exploded view shows each drain as a single piece. This may or may not be the case. GM may service this as an "assembly", in which case it may be a rigid upper drain tube with an attached flexible tube toward the bottom where it will ultimately exit the side of the vehicle. If this is the case, the two pieces have likely come apart in which case your dash will need to come out.
    If this is in fact a single drain, it may have come apart at the connection where it exits the side of the vehicle. If this occurred, you may be able to pull the drain out from the side of the car to (hopefully) reattach the connection without removing the dash. I wouldn't hold my breath on this option, however.
    Is there any sign of leaking into the headliner? It is conceivable that the drain detached from the sunroof assembly and water is running down the headliner, pillar and to the floor. I don't think this is likely the cause either, but it's possible. You would see signs of water leaking into the headliner. By removing the 'A' and 'B' pillar trim, the grab handles and pulling the door opening weather strip down, you should be able to gently pull the headliner down enough to see if this is the case and to visualize the drain connections.
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Id bet its your HVAC drain clogged and NOT your sunroof.
    That drain is accessible just to the right of the gas pedal behind the carpet. Its a rubber 90 deg elbow. Squeeze it a few times and see if water comes pouring out.
    Oct 2013
    6
    I will verify
    Thanks
    ddalder's Avatar
    Aug 2008
    Canada
    2,800
    Sorry, I got the impression that it had not started leaking inside until after you cleaned the drains with wire. Also, you still have not mentioned which side the water leak is on.
    Oct 2013
    6
    The leaking in both sides of the dash. This morning I supply some water through the drains with a bottle an the leaking start again. Now I need to rich the drains connection. Did someone Know or have a repair manual for this model. BTW the wire was not sharp its had a lope. It may disconnect the house from the base.
    ddalder's Avatar
    Aug 2008
    Canada
    2,800
    There are a couple of options for a service manual. The first, which many seem to use, is www.alldata.com. You can subscribe (fee unknown) to a specific vehicle for a period of one year (if I recall correctly). Alternatively, you can also subscribe to the same Service Information system that GM dealerships use at www.acdelcotds.com. There are different options, but for $20 you can subscribe for three days. This system covers all GM vehicles and you are not limited to just one during your subscription period.
    The news is not good. Like I mentioned, I've had my dash out twice now (second time was far easier), but this isn't going to be a two or three hour fix. I looked at the procedure to replace the drains (you may not need to actually replace them, so not all of the steps may be required), but if they are, GM specifically notes that you must remove the front doors to properly access the drains in the door jambs. Again, depending on what you find, this step may not be required.
    Best of luck with this.
    Oct 2013
    6
    Thanks for the information I have a ? if take out the Pillar A & B the airbag will not explode?
    Quote Originally Posted by ddalder View Post
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    ALWAYS disable the SIR system when working near any if the airbags.
    ddalder's Avatar
    Aug 2008
    Canada
    2,800
    As Moist says, be sure to disable the Supplemental Restraint System first. You can do this by removing the fuse and letting the car sit for 1 minute. The specific disable/enable procedure is in the GM Service Information, and I assume it will be on the AllData site as well. I only ever use the GM information myself. Hopefully all goes well for you.
  13. Remove Advertisements
