Location of Heated Steering Column Fuse
Results 1 to 6 of 6
Cadillac STS Forum - 2005 through 2012 Discussion, Location of Heated Steering Column Fuse in Past Cadillac Vehicle Discussion; The heated steering column in my 2005 STS is no longer working. I went to check the fuse (HTD STG/CLM) ...
    SusanM is offline Cadillac Owners Member
    Automobile(s): STS 2005
    Apr 2012
    56
    18
    The heated steering column in my 2005 STS is no longer working. I went to check the fuse (HTD STG/CLM) and the block is supposedly located underneath the rear seat, passenger side. I am not finding any fuse box on either side. Any guidance greatly appreciated!
    Thanks,
    Susan
    sub613's Avatar
    sub613 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 STS 1SF N* RWD NAV F55
    Mar 2009
    NC for Now, Florida SOON
    704
    CoolRe: Location of Heated Steering Column Fuse
    This has been hashed here, over and over, mostly the heater is burned out.As mine is.
    and replacing the whole steering wheel fixes the problem.
    The fuse is accessable, by removing the bottom of the rear seat.
    and you will see two fuse boxes, behind respectively, driver and passenger.
    on the front side of the base of the seat. facing up.
    If you have ANY warranty, they "MAY" fix it, , but probably NOT.
    The extended warranties are mostly for drivetrain stuff.
    You have a 8, going on 9 year old vehicle.
    Wishing you LUCK.
    Happy Motoring.
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Have to pull up the carpet a bit
    Think if you were sitting in the seat the fuse boxes are behind your ankles.
    Sub hit the nail on the head though you have a bad element in the steering wheel and being you have an 05 they are discontinued.
    KRSTS Guest
    Probably the wheel and not the fuse. Good luck!
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    One member recently reported a dealer replacing his wheel but requiring the old wheel as a core exchange with the total price below the 'book' price of the unavailable part. If I have the facts right, it sounds like somebody has found enough demand to start a refurbishing operation.
    I hope so. I'm spoiled by my heated wheel and Winter is coming!
    Apr 2012
    56
    18
    Quote Originally Posted by 1BadCadSTS View Post
    Ah, okay. I followed the diagram in the manual and it showed them as being located right underneath the top of the seats, not at ankle level. Many thanks!
    Thanks again,
    Susan
  9. Remove Advertisements
