replacing shift solenoid
Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By ddalder
Cadillac STS Forum - 2005 through 2012 Discussion, replacing shift solenoid in Past Cadillac Vehicle Discussion; My 05 STS shift solenoid is not working I am engaging out of park with the help of a screwdriver ...
    sjs05sts is offline Cadillac Owners Member
    Automobile(s): 05 STS
    Oct 2010
    50
    35
    Questionreplacing shift solenoid
    My 05 STS shift solenoid is not working I am engaging out of park with the help of a screwdriver I went to my local dealer and purchased a new solenoid to $80 has anyone replaced this part yet and if so how is it done?
    ddalder's Avatar
    ddalder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-4 N* 1SG, 08 DTS Luxury II, 04 Bonneville GXP N*
    Aug 2008
    Canada
    2,815
    Re: replacing shift solenoid
    I don't think I've ever heard of one going bad, not that it isn't possible. What diagnostic steps did you take to confirm it is the solenoid and not either wiring or the controlling module?
    Oct 2010
    50
    35
    I recently had some work done at the dealer so I was able to have the dealer confirm that it appears to be the solenoid after he hooked up the computer to diagnose to problem I was quoted $500 to repair the problem. Today I attempted to install the solenoid but was unable to remove the center console due to fear of breaking it so does anyone know how to remove the console correctly.
    ddalder's Avatar
    Aug 2008
    Canada
    2,815
    The console is actually quite easy to get out. Mine has been out on a few occasions. There are eight bolts that hold the console in. You must pull the carpet down from along the sides of the console to access these. There are four on each side, two at the front and two at the rear. If this has never been done, the carpet may be quite stiff. You'll need to move the seats fully forward to access the rear bolts. As for the carpet, I'd start pulling it down at the front and then move rearward.
    You can see in the photo below, there is a black bracket toward the rear of the console. There are little tangs which can catch if you're trying to lift it up. You may need to slide a screwdriver in to pry this slightly outward. I'm assuming that you haven't had any difficulty removing the other necessary trim around the shifter...
    Guy.Seminerio likes this.
    BarrySTS is offline Cadillac Owners Member
    Automobile(s): 2008 STS NS
    Jan 2010
    42
    My neighbor has a newer type Impala and the shifter solenoid stopped working. I fixed it for her and it was a broken wire going to the solenoid, right at the connector going into the solenoid. If I remember correctly, the Impala solenoid "rides" with the shifter so the wire is flexed constantly.
    Be sure to check the wiring as well.
    Oct 2010
    50
    35
    Great thanks this helps a lot I will give it a try maybe this weekend I am still using a screwdriver to get out of park I will let you know if I get it...yes I remove the wood grain parts around the shifter no problem.
    KingMack is offline Cadillac Owners Member
    Automobile(s): 2005 STS 3.6L V6
    Mar 2011
    30
    43
    Wow, I know this is an old post but it also kind of seems like my issues but only my STS says shift to park while in park. How did replacing that solenoid work for you? Maybe I need to do the same since the shifter seems to be obsolete now.
    Thanks,
    Fina11y is offline Cadillac Owners Member
    Automobile(s): '07 STS
    Dec 2013
    Florida Panhandle
    11
    How do you even do the screwdriver trick in this car? I'm stuck in park, been happening intermittently, and I can't even figure out where the bypass is.
    I'm in an 07 STS 6 by the way. Anybody?
    mkosharkii's Avatar
    mkosharkii is offline Cadillac Owners Fanatic
    Automobile(s): 2007 SRX4 N* MRC, 2014 Corvette Z51 3LT, 1979 KZ1000 LTD
    Sep 2011
    Norfolk, VA
    32
    223
    -Open the center console lid.
    -Remove shifter/console bezel (plastic part that surrounds the shifter area and cup holders). It pulls off lifting straight up.
    -Remove the wood trim plate.
    -The park solenoid is down at the base of the right side of the shifter assembly, towards the forward end. It looks like a small rectangular box with a metal rod sticking out towards the back of the car. It is only a few inches long. Push the rod towards the front of the car.
    I just replaced mine a week ago. You have to lift the whole console out, which is actually very easy.
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    I believe I read about a release that was easier, but it was quite a while back. I think it involved putting the car in run mode (like accessory, but hold the switch for 5 seconds.) Then there's a slide, but the details elude my recall. Maybe it involved shift knob.
    Amigobear718's Avatar
    Amigobear718 is offline Cadillac Owners Member
    Automobile(s): 2007 cadillac sts v6
    Jan 2015
    29
    47
    I have the same problem. Every time I go in to park n try to shut off car it tells me to shift into park n just keeps beeping until I hold the brake with the car off n shift into Neutral n back into park n than it stupid beeping. This does not work all the time. what's the fix ? n is this going to get worse ? What are my options?
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Quote Originally Posted by Amigobear718
    Adjust linkage
    Replace shifter
    Mar 2011
    30
    43
    good luck with both of those, i have replaced my shifter and adjusted my linkage and I am still getting this error. smh!! Its the worse.
  16. Remove Advertisements
