Down steam O2 sensor
Results 1 to 7 of 7
Cadillac STS Forum - 2005 through 2012 Discussion, Down steam O2 sensor in Past Cadillac Vehicle Discussion; From time to time I will get a cat inefficient code out of bank 1. I looked at the voltage ...
    SuperSparr is offline Cadillac Owners Member
    Automobile(s): 2006 STS V8, 1999 SLS
    Mar 2013
    Hudson WI
    34
    4
    From time to time I will get a cat inefficient code out of bank 1. I looked at the voltage on the 4 O2 sensors, and they are not mirroring each other. But I can see a bit of an issue with the one cat. It is still working, but maybe not as well as it could.
    My question is does the down stream O2 reading have any effect on fuel trim levels? I know on most cars guys would always tell you that the down steam was just because of government mandates but would not effect your car running. Now on newer Chryslers the down stream O2 talks to the up stream and they talk to the computer.
    Just not sure if Cadillac did that. This is on my 06 STS 4.6
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,496
    Re: Down steam O2 sensor
    Chances are yes this would change fuel trims a bit.
    There was / is an extended CAT warranty on certain model year and engine option STS/SRX.
    Might be worth a call to the dealer with your VIN to see if this car is covered by it.
    Mar 2013
    Hudson WI
    34
    4
    8 years ir 80k miles. I am passed that.
    ddgm is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS
    Jun 2009
    Hamilton, ON & Fort Myers, FL
    270
    I think the extended warranty is 10 years, 120000 miles, doesn't hurt to check.
    Mar 2013
    Hudson WI
    34
    4
    I just called Cadillac and had them look up my VIN, the 2006 STS is not covered under any extended warranty.
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Quote Originally Posted by ddgm
    04-05 sts srx and xlr with rpo LH2 ONLY
    BaTu is offline Cadillac Owners Enthusiast
    Automobile(s): '05 STS4
    May 2008
    668
    I just had a CAT replaced on my '05. They extended it to 12yr/200K in my letter!
  10. Remove Advertisements
