05 STS with clicking/popping sound in dash - Page 2
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 46
Like Tree6Likes
Cadillac STS Forum - 2005 through 2012 Discussion, 05 STS with clicking/popping sound in dash in Past Cadillac Vehicle Discussion; Originally Posted by Midnight There are actuators that control the air doors. They have a layer of resistive material that ...
  1. #16
    DarkMingBlueSTS's Avatar
    DarkMingBlueSTS is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS 6 CYL
    May 2012
    497
    Quote Originally Posted by Midnight
    There are actuators that control the air doors. They have a layer of resistive material that over time wears off. When it eventually wears through, it can cause them to click, as they move until the worn out part, and then think they need to move back, so they move back, onto the good part, repeating. Sometimes they get lucky and move through it to the intended position, then the clicking stops for awhile. I imagine once it starts to fail, it deteriorates rapidly with all the movement.
    Here's a picture of the inside of my failing actuator module. You can see it's worn all the way through in spots:
    They are like $40 a piece and kind of a bitch to install (at least my passenger side one was) because it's up inside the dash, I had to do the thing where you sit upside down in the seat, getting too old for that kinda maneuver And there was a screw that was hard to access. I have yet to do the driver's side one so maybe it's easier.
    Here's a picture taken looking "up" into the guts behind the dash on the passenger side. You can see the module in the center with the wires going into it.
    Anyway, if you hear clicking (I thought mine was the CD drive seeking) that seems to be coming from the dash, this could be the issue. Unfortunately, adding lube on them (even if you could, they are well sealed) wouldn't help at least in my case, you can see they still have a lot of grease, but it's already worn through so replacement is about the only fix.
    The drivers side is beyond tough to get to. The drivers side is the one that controls the temp. setting. Mine stays around 75 even though the display changes when I'm in ac mode, when I change it to heat I get full control and the clicking stops. Lol one day I'll change it out
  2. #17
    Midnight is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS 1SG
    Nov 2009
    Baltimore
    41
    308
    Re: 05 STS with clicking/popping sound in dash
    I just did the driver's side. It's hard for me to say which was harder. For the passenger I had to sit inverted in the seat (with head where your feet usually go) but once there, and with a stubby enough screwdriver (I took a stubby and cut about 3/4 inch off the handle to make it super stubby and used a small neo magnet to keep the screws seated), it was easy enough. Have to take the glove box out. I could do again in 15-20 min or so if I wanted to hurry, now that I know where everything is.
    Driver's side, you have to move the seat back all the way, move the steering up all the way, kind of enter the floor area face-down and twist around so you're facing mostly up -- not recommended if you have a bad back. There's about the same amount of room to work. You'll want your super stubby screwdriver for the upper screw. You can hook your right arm around the back of the brake pedal to get good access to that area. You will have to operate on the upper screw by feel only.
    I had to re-do the passenger because I actually installed the wrong side there. The passenger's "lever" part is slightly longer, but the driver's side one fits there. I noticed it when the other one, being too long, didn't fit. So the second time doing the passenger side was much easier, mostly owing to having a better tool. So just be warned that those actuators have the same body, and make sure you're installing the correct one if you're doing both!
    Hopefully this is helpful to someone
    This is a better view of the passenger side one:
    This is the driver side one:
    This is a comparison of the two. Identical except for length of the lever part. Passenger (longer one) on the left, driver (shorter one) on the right:
    Finally, DIY Special tool # 98234987234
  3. #18
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Mines the selector actuator. Which looking at it and GM confirms requires removing the ENTIRE dash carrier and substructure.
  4. #19
    nwjones18 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS V8
    Feb 2013
    Georgia
    29
    201
    Finally got around to looking at mine today. There are two actuators on each side. The upper one is bad on both sides of mine. On Rockauto they list 6 different acdelco actuators. Does anyone know the part numbers would be for the Top one on each side? The number that is written on them does not match the numbers on rockauto. Top one on the passenger side ends in 8580 on my car. Passenger side one shown above is the lower one and ends in 8590.
  5. #20
    Feb 2013
    Georgia
    29
    201
    Please see my pdf attachment for a Parts Diagram of the actuators I need.
  6. #21
    Feb 2013
    Georgia
    29
    201
    Quote Originally Posted by 1BadCadSTS View Post
    Well sorry to post so many times.. I just looked at mine again and read the service manual. I'm with 1BadCadSTS. The ENTIRE dash has to be removed. Good Lord what a job.
  7. #22
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Yup. Near me come on over. We can make a party out of it.
  8. #23
    johnny-cash is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS V8, 1998 Seville STS, 2006 STS-V Black Raven.
    Oct 2010
    Renton,WA
    29
    118
    been dealing with the same issue since day one
  9. #24
    galvez83 is offline Cadillac Owners Member
    Automobile(s): 2005 Cadillac STS
    Jun 2012
    7
    kquadra90 I was the one that posted the video on youtube about the buzzing noise and I found what it was with a mechanic stethoscope. It was hard to describe so I had a friend rev the engine lightly while I searched and I found the part that was buzzing. The part is located behind the engine close to the fire wall and you will hear the buzzing inside the vents and the front of the car.
    I will post pics and the part number and location but again that was my problem I don't know how close it might be to yours. Feel free to contact me and I will
    help you in any way I can.
  10. #25
    Feb 2013
    Georgia
    29
    201
    Well I finally got tired of the clicking and ordered all of the blend door motors from amazon. I'm going to start the dash tear down next week.. I'll try and get some pictures of the process. I just hope I do not break anything to expensive.. It is all 10yr old plastic.
  11. #26
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    A 'click' beats a 'fart'
  12. #27
    Feb 2013
    Georgia
    29
    201
    Took it apart this week. Took a lot of pictures and I finally got the actuators replaced this evening. I will begin reassembly on Sunday. Its been a slow process as I only work on it when I get time. Thankfully I haven't broken anything yet.. That I know of. Here's the current state of my STS.
    Midnight and GRODT like this.
  13. #28
    AllWheelEric is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS4 1SG
    Jan 2006
    398
    Quote Originally Posted by nwjones18 View Post
    OK, waitaminnit. You're fixing a noise in the dashboard? Holy crap! Do you also remove the hood and engine to make changing the cabin air filter easier? I forgot to take pictures when I did that.
    mIAn likes this.
  14. #29
    Feb 2013
    Georgia
    29
    201
    Really the only way to replace the mode actuator according to the FSM... All the actuators were bad and it was just a matter of time before they quit working. Figured I'd get it over with now rather than wait until its 100 degrees outside..
  15. #30
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Quote Originally Posted by AllWheelEric
    And people think I'm the forum sarcastic ass...
    Do you cut a hole in you ip to replace your hvac door motors and then glue it back in because that's the only way your going to access the defrost one without removing it.
  16. Remove Advertisements
