Bose rear shelf subwoofer doesn't work in car but does on bench!
Results 1 to 6 of 6
Cadillac STS Forum - 2005 through 2012 Discussion, Bose rear shelf subwoofer doesn't work in car but does on bench! in Past Cadillac Vehicle Discussion; Since I bought the car couple months ago the stock bose subwoofer installed on the rear shelf doesn't work. Recently ...
    kquadra90 is offline Cadillac Owners Member
    Automobile(s): 2006 Cadillac STS 3.6L V6
    Sep 2013
    26
    8
    Since I bought the car couple months ago the stock bose subwoofer installed on the rear shelf doesn't work. Recently removed the subwoofer for some testing and got strange results. The two wires connector to the subwoofer has constant 24V power and sometimes fluctuates to 48V when radio/stereo on. Then tested the subwoofer in another car using the cars door 2 speaker wires and it does play music and pumps too. I just don't understand when it has power and works in other car then why doesn't it work in my car!? Any help is appreciated. Thanks
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,055
    Quote Originally Posted by kquadra90 View Post
    The amplifier could be toast. Not sure if it has its own or if it's a part of a multi channel amp. Someone with more knowledge of the system should chime in...Also, is this the base stereo or the 15.1 Studio Surround? My money is on the amp...
    Ludacrisvp's Avatar
    Ludacrisvp is online now Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,537
    The two front door speakers and the sub have an amp mounted to the top of the speaker (for the 15.1 setup at least) the rest of the speakers are powered by an amp in the trunk wall behind / in front of (depending on your point of view) the passenger side tail lamp assembly.
    Sent from AutoGuide.com Free App
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Is your dsp setting on talk or front seat? That will reduce the deck sub output significantly.
    Sep 2013
    26
    8
    Re: Bose rear shelf subwoofer doesn't work in car but does on bench!
    No I don't think so the amp is toasted as I still get power at the connector wires when I check with a multi-meter. Its a base stereo, 1 speaker in each door and it looks like 1 speaker on the dash(I see a grille) and the rear shelf sub, that's it.
    Amp is good
    Quote Originally Posted by Ludacrisvp View Post
    Base stereo, no dsp settings
    Quote Originally Posted by 1BadCadSTS View Post
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    There are some folks that repair Bose systems; usually worth the money. New replacements can be spendy.
    Dr. Bose is very proud of his designs but has always used inexpensive components to achieve better than expected sound.
  9. Remove Advertisements
