New 2005 STS N* owner here...
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
Like Tree1Likes
Cadillac STS Forum - 2005 through 2012 Discussion, New 2005 STS N* owner here... in Past Cadillac Vehicle Discussion; Hi all! The owner is new I should say. The car is an '05 and is pretty heavily loaded from ...
    trailbrake is offline Cadillac Owners Member
    Automobile(s): 2005 STS Northstar
    Jul 2013
    45
    8
    CoolNew 2005 STS N* owner here...
    Hi all! The owner is new I should say. The car is an '05 and is pretty heavily loaded from what I can tell with navi, int. cruise and a whole bunch else. I've been lurking for a few months trying to figure some stuff out, like does it have an LSD on top of the stability / traction control, are my wheels different width f to r, etc. When these tractionless wonders are worn out I'd like to commonize tire widths to allow rotation.
    Overall I love the car although the mileage is a real bummer. I have about a 90 mile rt commute each day and feeding this thirsty beast gets a little painful at the pump. Anyhow, I thought I would say hi and I look forward to learning lots more.
    Oh one more thing I was wondering about. I'm looking at ideas for exhaust systems. I know this engine would sound fantastic uncorked and I'm looking at the cost vs quality tradeoff. What's the best option?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,924
    Re: New STS N* owner here...
    Given the couple of model-specific questions, let's move this from the chit-chat Lounge to the new "STS" forum.
    Welcome Aboard !!!
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Quote Originally Posted by trailbrake
    Only 1sc 1sf and 1sg cars got posi you'd have to check your rpo codes.
    The tires are staggered with wider rims on the rear for the 17" standard wheels. Optional 18"s are the same front to rear.
    Exhaust choices are GMPP (Borla) or corsa. Both are expensive as well as Gibson which isn't too bad price wise.
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    Re: New 2005 STS N* owner here...
    The 07 sts northstar I had had the 18s with wider tires in the rear. Just read the tire sizes off the sidewalls of the tires and compare front to back.
    mjcaddy's Avatar
    mjcaddy is offline Cadillac Owners Fanatic
    Automobile(s): 09 1SG STS4 & Subie CrossTrek (retired 03 DeVille & 05 V6 SRX4)
    Oct 2010
    Chicagoland
    32
    421
    ^ same here, with the optional 18" 235 fronts and 255 backs
    sub613's Avatar
    sub613 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 STS 1SF N* RWD NAV F55
    Mar 2009
    NC for Now, Florida SOON
    704
    There is a White tag in the trunk, attached to the Spare tire cover, it lists
    all the Toys, your car came with. as mentioned above, the package is
    also on the tag, NOt the 1SZ, but the other 1XX, fill in the blanks.
    Happy Motoring.
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Quote Originally Posted by Guy.Seminerio View Post
    I think this is only with the upgraded V-series brakes & six-lug wheels. The other 18" wheels are matched, but I'd give that up in a heartbeat for the brakes. Again, if 18" wheels and not AWD, you probably do have posi!
    For all the proof, open your trunk & the spare tire cover & read the label with your VIN. Each three letter code tells a truth!
    Oops, Sub wins!
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,033
    Quote Originally Posted by EChas3 View Post
    Oops, Sub wins!
    My 06 1SF has the 18" staggered setup, 235/50 in front, 255/45 in back. I have the performance brakes, not the 6-lug/Brembo setup.
    achavez's Avatar
    achavez is offline Cadillac Owners Member
    Automobile(s): 2005 STS 4.6ltr 1SE
    Aug 2013
    California
    31
    34
    op I will probably be doing a muffler swap with a pair of magnaflows and some tips end of October. I will try to post a video. im assuming ill spend in the $400ish range
    Jul 2013
    45
    8
    Thanks for the replies guys. 18" staggered and not AWD. I'll check in the trunk this weekend. I didn't know about the Brembos (jealous!). That's the other real weakness I've found so far. The tires are deadly and the car is fast enough to completely overwhelm the brakes. I'll be upgrading both as these wear out, but looking for a potential Brembo find over just better pads.
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Quote Originally Posted by curtc View Post
    Your wheels should all be identical; only the tires are different. The 17" staggered setup uses back wheels that are 1/2" wider.
    Feb 2013
    Whitestone, NY
    28
    3,211
    Page 438 in the 2007 manual says that tire rotation is not recommended if you have one of the following performance tire combinations, and one of the combos is 235 50 18s up front and 255 45 18s rear.
    V Force likes this.
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    My DPO & their dealer never read the manual. They did it three times.
    I convinced the selling dealer to put them back on the right ends. It wasn't all that long until I changed to the same size Conti DWS on all corners.
  16. #14
    Jul 2013
    45
    8
    Conti Sport DWS's are on sale right now too. Very tempting if I weren't also building a motor right now... Interesting news about wheel width on the 18's. I'll double-check with a tape measure just to be sure.
  17. #15
    Feb 2013
    Whitestone, NY
    28
    3,211
    On sale where?
  18. Remove Advertisements
