Moisture in 2007 STS-V headlight - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
Like Tree1Likes
Cadillac STS Forum - 2005 through 2012 Discussion, Moisture in 2007 STS-V headlight in Past Cadillac Vehicle Discussion; Search mjcaddy's posts. He posted a few vids, but in short, you'll want to remove two pop-pins on each side ...
  1. #16
    eatyoursandwich is offline Cadillac Owners Fanatic
    Automobile(s): 2007 STS N*
    Jan 2012
    Austin, TX
    31
    265
    Re: Moisture in 2007 STS-V headlight
    Search mjcaddy's posts. He posted a few vids, but in short, you'll want to remove two pop-pins on each side that fasten the fenderwells to the fender. Just enough to pull back the fenderwell, you don't need to completely remove them.
    Once the fenderwells are pulled back, you will see two bolts that hold the bumper onto the fender. Remove the two bolts from each site (8mm IIRC - you will need a deep socket for 1 of them). Pop the pins off the top of the bumper (above the grill) and slowly drop the bumper.
    Obviously you want to have a could pieces of cardboard or something soft to put the bumper on so it won't scratch. Unplug the headlight and foglight harnesses and you're done.
    It helps to remove the front wheels too, but I have a lift and air tools so my 30 min estimate might take a little longer with jackstands and a lug wrench.
  2. #17
    sub613's Avatar
    sub613 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 STS 1SF N* RWD NAV F55
    Mar 2009
    NC for Now, Florida SOON
    704
    When I had the doors off, Instead on relying on the gasket material to seal.
    because, after I replaced it once, it still leaked, I have an 06, and it is a rubber
    gasket, I used Permatex NON HARDENING on both sides of the gasket,
    TO BE SURE, I also had two small holes I drilled on the bottom of each
    light, Let them dry completely in the sun, and then sealed the holes with glue.
    No problem since, Yeaaaaaaaaa.
    Happy Motoring.
  3. #18
    kquadra90 is offline Cadillac Owners Member
    Automobile(s): 2006 Cadillac STS 3.6L V6
    Sep 2013
    26
    8
    L shaped headlight vent for the Passenger(Right) side headlight located at the bottom left of the assemble in the picture
    Sent from AutoGuide.com Free App
    atlrus likes this.
  4. #19
    hisbosschick is offline Cadillac Owners Member
    Automobile(s): 2002 cadillac dts and 2007 cadillac stsv
    Sep 2013
    32
    13
    thanks guys for the info but we are gonna try to have the body shop get the moisture out when they fix the bumper.....my boyfriend hit a raccoon this am and it messed up the passenger side bumper and the metal mesh grill pretty bad so we have to take it to get it fixed so we r going to see if they can get the moisture out of the headlight when they are fixing it. we r hoping it is not going to cost a lot to have it fixed.... does anyone know about how much it might possibly cost to have it fixed?
  5. #20
    sub613's Avatar
    Mar 2009
    704
    Do you have Collision coverage on your insurance?
    Deductible ?
    Happy Motoring.
  6. #21
    Sep 2013
    26
    8
    If the bumber needs to be replaced then your pockets gonna get lighter, hope you have many pockets, lol. But you gonna save many getting the moisture out of your headlights because anyways the bumper have to be removed to remove the headlight assembly.
  7. #22
    Sep 2013
    32
    13
    yeah we definitely have comp and collision on it. yeah it will probably cost us an arm and a leg to get the bumper fixed but we figured since they are gonna have the bumper off we might as well ask them to fix the headlight problem. if it is not one thing its another I told him it is now time to park it for a while he tries not to drive it that much because of putting a lot of miles on it but he has been having to drive it because our other caddy was down for a lil and now this happened we cant catch a break......
  8. #23
    james6speed's Avatar
    james6speed is offline Cadillac Owners Fanatic
    Automobile(s): '07 STS 1SG ~ '13 Sonic RS Turbo ~ '87 944 Turbo
    Nov 2013
    117
    Quote Originally Posted by kquadra90 View Post
    Okay so this L shaped rubber piece can get plugged and cause condensation in the light, is that correct? Also, you have to remove the headlight housing to get to this vent is that correct?
  9. #24
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Quote Originally Posted by james6speed
    Yes on both accounts.
  10. Remove Advertisements
