steam/coolant coming from exhaust pipes time to sell?
Page 1 of 2 12 LastLast
Results 1 to 15 of 26
Like Tree5Likes
Cadillac STS Forum - 2005 through 2012 Discussion, steam/coolant coming from exhaust pipes time to sell? in Past Cadillac Vehicle Discussion; dealer said my 06 1sg had internal coolant leak with the help from everyone here I was able to figure ...
    edoubble2082 is offline Cadillac Owners Member
    Automobile(s): 2006 sts4 v8 has every option available
    Aug 2013
    44
    dealer said my 06 1sg had internal coolant leak with the help from everyone here I was able to figure out it was a small leak and not going in to the oil .I am quite sure its burning through the tail pipes because they steam always and I saw moisture inside the exhaust pipe is there a fix with out rebuild or new engine and over time will it cause head gasket problems is it time to sell thanks
    KRSTS Guest
    Re: steam/coolant coming from exhaust pipes time to sell?
    Small leaks become big ones
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,055
    Have you done any other tests to validate the HG has failed??? Have you performed a block test to confirm the presence of exhaust gases in your cooling system? I've never heard of a Northstar mixing the coolant and oil after HG failure. Does it ever overheat?
    tking5830 is offline Cadillac Owners Member
    Automobile(s): 2006 STS 3.6
    Jul 2013
    31
    38
    Quote Originally Posted by curtc View Post
    I know the old seville's had a MAJOR problem with headgasket failure and one of the sure signs of issues was coolant in the oil
    Aug 2013
    44
    The head gasket has not failed yet but its burning oil and coolant slowly no milky oil or anything oil kooks perfect so I believe its burning out through the exhaust
    The head gasket has not failed no block test yet but its burning oil and coolant slowly no milky oil or anything oil looks perfect so I believe its burning out through the exhaust
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,055
    Quote Originally Posted by tking5830 View Post
    False, very rare actually.
    wake's Avatar
    wake is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 STS-V, 2007 Escalade, 2003 Escalade EXT
    Sep 2003
    Stafford, VA
    812
    I don't think it was that rare. It was common enough that GM had a service procedure to deal with the problem, timeserts if I remember correctly. I've had three previous FWD Northstar cars and can't remember how many times I've read about keeping mindful of the coolant change intervals to prevent this type of failure.
    Out of the three previous generation NS cars I've owned though, two of them had the case half reseal done early in life, under factory warranty. That was always a worry for me, more so than I think the head bolts pulling out of the block. I usually purchased the vehicles right around 5-6 years old so the first thing I did was change the coolant since I didn't have a known history to go by.
    Quote Originally Posted by edoubble2082 View Post
    I think it depends on how you feel about the car overall. If it's pristine with all options as you note then I'd probably get the problem fixed or engine replaced when it does finally fail (more expensive option). Who knows, it may go 10-20K more miles before that happens. If it's an average condition vehicle then I might get rid of it for another. Also, if you bought the car new you know the entire history that also would make me think about repairing it. It would be a shame to replace the vehicle with another used car only to find out you got unlucky and wound up with someone else's problem. Who knows, you could wind up with another vehicle that someone got rid of for a similar reason you're thinking about getting rid of yours.
    If it's paid off then there's another vote for fixing it. Maybe a $4K repair but that's better than starting out again with a $20K+ loan on another used vehicle.
    Aug 2013
    44
    Thanks for the advice I got the car for 7 grand with 100k on it it is paid off :-) salvage title put a quick 30k on it and know the compressor for air ride needs to be replace d and front shocks making noise .I want to keep it but if the engine s on its way out and I'm thinking mrc replace around 160k rides pretty rough with the mrc and engine that's easy what I paid for the car again .Might be smarter to let it be someone else problem and try to sell now for 10 while it still idels and drives fine before I'm in to deep I also know I will probably never find a 1sg for that cheap wish I new how to work on wrench on these cars I would keep no problem kinda feels like its falling apart around me anyway thanks for the advice got all my friends in my ear telling me to sell but I ****ing love this car just don't want to be stupid and can't afford to make the wrong dissison
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,263
    Blown head gaskets are common in older NorthStars but because of block and head design it is very rare for this to result in coolant leakage into the oil. The result is predominantly exhaust gases leaking into the coolant, thus the definitive test is for exhaust gases in the coolant with a block test kit.
    Don't mess with Binky Bear!
    Aug 2013
    44
    Sound like block test is the way to go bad experience with dealer is this something local shop could competently do and let's say test says there is exhaust gas in coolant I'm looking at new engine quick or can possibly drive the life of the engine like this ?
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,055
    You can do it yourself. Most chain parts stores should have a block test kit you can rent. Google it, it's actually quite simple.
    Aug 2013
    44
    Will do thanks
    mjcaddy's Avatar
    mjcaddy is offline Cadillac Owners Fanatic
    Automobile(s): 09 1SG STS4 & Subie CrossTrek (retired 03 DeVille & 05 V6 SRX4)
    Oct 2010
    Chicagoland
    32
    428
    if i remember this correctly they changed the design after 05 or 06 to fix the HG problem, maybe someone here can confirm that,
    but as the guys mentioned here do the test yourself and if you suspect something is not right, then maybe think about selling.
  16. #14
    Charles Warren's Avatar
    Charles Warren is offline Cadillac Owners Fanatic
    Automobile(s): 2008 sts-v black raven 2004 cts black raven
    Nov 2011
    Atlanta, Georgia, United State
    88
    459
    rwd is not open deck like fwd northstars. totally different design.
    mckellyb likes this.
  17. #15
    Aug 2013
    44
    Block test came up positive :-( mabie time to sell or just drive off a cliff put us both out of our missioury thanks for the advice guys it hurts me to sell this car wish there was a way to fix damn I did my reaserach and bought this car because I thought they fixed the hg problem just my luck
  18. Remove Advertisements
