debris flying out of ac vents
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By EChas3
Cadillac STS Forum - 2005 through 2012 Discussion, debris flying out of ac vents in Past Cadillac Vehicle Discussion; past week and a half I have had chunks of grey/black foam flying at me through the ac vents. im ...
    achavez's Avatar
    achavez is offline Cadillac Owners Member
    Automobile(s): 2005 STS 4.6ltr 1SE
    Aug 2013
    California
    31
    34
    Questiondebris flying out of ac vents
    past week and a half I have had chunks of grey/black foam flying at me through the ac vents. im assuming its some type of gasket for the doors in side the ducts. anybody else have this happen to them? its a rare thing I haven't heard of too much in a car of this age (8yrs)
    thanks,
    Adrian
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: debris flying out of ac vents
    Center vents only? How long since the bezel around the HVAC & radio controls has been removed?
    achavez's Avatar
    Aug 2013
    California
    31
    34
    Actually yes. Only the driver and pass center vents. I've only had car for 6 weeks. I haven't removed the bezels
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Odds are somebody did and wasn't careful when reinstalling it. There's a dark grey foam between the vent louvers on the bezel and the ductwork behind the dash. You probably need to remove & re-install it.
    It's a push-fit but the wood trim at the bottom is so narrow it can easily crack. It's a pricey piece, to be sure. I can't remember exactly where the mounting clips are but with some non-marring tools, it's an easy R & R.
    Charles Warren likes this.
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    Bottom left and right, middle left and right, top left and right. I wrapped a microfiber towel around a prying style trim tool and got it out like that. The middle ones were easy to find for me and for 2008+ because its where the aluminum meets the wood. Either way, those are the locations of the mounting clips.
    uae666 is offline Cadillac Owners Member
    Jul 2013
    1
    I had the same problem of foam melting, i thnk that is because of heat !
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Southern Ca?
    achavez's Avatar
    Aug 2013
    California
    31
    34
    Im in the central Valley... the foam that flew out didn't really look melted. Im going to have to find time to carefully remove the trim around the vent and radio to make sure all is well.
    Feb 2013
    Whitestone, NY
    28
    3,211
    If you're sitting on the passenger side, there is a horizontal line that separates the top of the dash from the bottom. (It's really one piece) follow that line to the left until you hit the wood that surrounds the center stack. That part of the wood is where the center clips are.
  12. Remove Advertisements
