It ONLY happened ONCE !
Results 1 to 11 of 11
Cadillac STS Forum - 2005 through 2012 Discussion, It ONLY happened ONCE ! in Past Cadillac Vehicle Discussion; FYI: On my 2005 STS if I got out the car, with engine running, with FOB in pocket,door shut,the car ...
    sub613's Avatar
    sub613 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 STS 1SF N* RWD NAV F55
    Mar 2009
    NC for Now, Florida SOON
    704
    CoolIt ONLY happened ONCE !
    FYI:
    with FOB in pocket,door shut,the car would 3 beep .
    On my 2006 STS,IF I get out of car, with FOB in pocket,
    door shut,NO beeps !
    ONCE, I got of car, like regular, with Engine OFF,
    with FOB in pocket, with door shut,
    and car 3 beeped ,again, 3 beeped,
    and kept on, until I hit the Lock or Unlock,
    don't remember. But it only happened,ONCE.
    Hopefully Never again.
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    Re: It ONLY happened ONCE !
    Mine doesn't do it if its running.
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,241
    Check your lock personalizations.
    Feb 2013
    Whitestone, NY
    28
    3,211
    I don't remember an option where the car locks while the engine is running if the fob leaves the car. I could be wrong.
    I'm pretty sure there's no option where the horn will continue to go off over and over if you leave the fob in the car. Just 3 horn sounds. I don't think I'm wrong on that one.
    sub613's Avatar
    Mar 2009
    704
    The car auto locks, as always,I never mentioned locking.
    Just the Beeps. FOB in Pocket.
    It ONLY did it ONCE !
    Feb 2013
    Whitestone, NY
    28
    3,211
    Clearly some kind of glitch. Oh well. See what happens.
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,046
    Mine only beeps 3 times with fob in the car, engine off...
    No beep if left running with fob in the car...
    Locks when running with fob away from the car.
    Leave the extra fob somewhere else in the car??
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Nice discovery for after a carwash & drying... Put the car in Accessory Mode & it won't chime while listening to the radio with the doors open!
    Feb 2013
    Whitestone, NY
    28
    3,211
    WHAT!? Driver's door is the only door that's supposed to chime. Acc mode and your driver's door is open with no chime? Lucky. Something must be wrong though.
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    OK, I couldn't find this in the owners manual, but it is an extension of Accessory Mode where all the cars systems are powered. Perhaps it is a diagnostic mode that a member with a shop manual or other resources can find more details. Here's how I use it:
    1. Stop the engine normally.
    2. Press & hold the bottom of the Start/ACC button for about five seconds.
    3. All the cars systems including HVAC and all the instrument displays will come on.
    4. I open all the doors, turn up the radio & dry the car or whatever I want to do while enjoying the radio without a single chime.
    5. So far, I've never had RAP shut anything off, but maybe I haven't waited long enough.
    I think that's as designed. Both my 2006 and my wife's 2007 do this. Does anyone's STS not work this way?
    Feb 2013
    Whitestone, NY
    28
    3,211
    Yes that's called "on". There's acc, on, and start. It's basically as if your car was running minus the engine. I guess I could just do that.
  14. Remove Advertisements
