Deer Warning Whistles - Effective Placement?
Results 1 to 13 of 13
Like Tree6Likes
  • 1 Post By EChas3
  • 1 Post By 1BadCadSTS
  • 1 Post By Submariner409
  • 1 Post By Cadillac_Fan
  • 1 Post By dkozloski
  • 1 Post By Guy.Seminerio
Cadillac STS Forum - 2005 through 2012 Discussion, Deer Warning Whistles - Effective Placement? in Past Cadillac Vehicle Discussion; My wife is a long-standing believer in deer warning whistles; you know, those pairs of cheap stick-on plastic that supposedly ...
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    My wife is a long-standing believer in deer warning whistles; you know, those pairs of cheap stick-on plastic that supposedly broadcast two tones that deer notice and might avoid. While I don't press the issue in the name of marital bliss, IMHO driving in Wisconsin is not a question of if you hit a deer, it's when and how many.
    For argument's sake, let's say those do-dads help reduce collision damage. Where is a good mounting point? Typically, they are stuck to a surface parallel the road. Any ifeads (s/b ideas) for as good location on the 'payoff?
    Cadillac_Fan likes this.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Air needs to flow through them, there stem't that many mounting options. The opening in the front needs to face forward, and can't be blocked. The bumper is pretty much the only spot to consider, unless you want them on the roof, hood, sides of the doors, or on top of the mirrors.
    http://advance.uconn.edu/2002/021118/02111812.htm
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Garbage can sounds good.
    In all seriousness I would mount them under the front bumper. Great airflow and no embarrassment as no one will see them.
    Ludacrisvp likes this.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,264
    Re: Deer Warning Whistles - Effective Placement?
    The standard joke about "deer whistles" over here on the Shore (crawling with deer) is that they let the critters know you're coming so they can jump you.
    The things are useless - they fall into the same class as stick-on fender vents. In the fall - rut season - your best bet is to drive cautiously with one eye on each road shoulder, especially at dawn and dusk.
    Faith76 likes this.
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,531
    From MoistCabbage's link
    "We tested them strictly from an acoustical point of view," explains Scheifele. He found that the whistles typically produce a signal either at a frequency of 3 kilohertz (kHz) or 12 kHz. Both, as it turns out, are problematic.
    The hearing range of white-tailed deer, the most common species in the United States, is between 2 kHz and 6 kHz, so the animal is not capable of hearing the 12 kHz signal.
    Although deer may be able to hear the 3 kHz signal, it is only 3 decibels louder than the road noise created by the car, so the signal is buried. Scheifele points out that the situation would be worse with additional traffic in the area or if the wind was blowing.
    Sounds like they would agree with 1BadCadSTS's idea of placing them in the garbage can.
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,241
    In the jockey box with the rest of the junk.
    Cadillac_Fan's Avatar
    Cadillac_Fan is offline Cadillac Owners Fanatic
    Automobile(s): '92 Brougham d'Elegance 305; '98 Seville STS
    Jun 2005
    Metro Detroit, Michigan
    490
    "A happy wife makes for a happy life." They're cheap and they will not harm the car; stick them on and make your wife happy. (However, I would not put too much faith in them.)
    I placed a set under the bumper of a '79 Fleetwood Brougham I once owned. The front nozzles of the whistles were clogged with bugs after my first hourlong interstate drive. Amusingly enough, mine came with a miniature plastic key to remove the whistles from their base (presumably anti-theft), which I found quite laughable.
    Faith76 likes this.
    KRSTS Guest
    scott9001 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 sts N* 1965 coupe deville
    Aug 2011
    26
    364
    why would you not want to hit them? they make awesome pepperets! using a rifle is better though you don't have to pay the deductible...
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,241
    Put the deer whistles on a stick so your wife can hold them out the window when she's in the car.
    Faith76 likes this.
    Faith76's Avatar
    Faith76 is offline Cadillac Owners Enthusiast
    Automobile(s): 89 Sedan DeVille, 90 Fleetwood, 94 Fleetwood Hearse
    Jul 2013
    Fredonia, NY
    41
    557
    My SDV came with them mounted right inside the grill. I see deer a lot, but have never hit one. Also, this car hasn't (knock on wood). Could be luck, I don't know. I've never hit a deer with this or any other car.
    Quote Originally Posted by scott9001 View Post
    I kind of want some bull horns. This might be a good substitute.
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    Well there's one thing that tells you.. It can't hurt.
    Faith76 likes this.
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Quote Originally Posted by Cadillac_Fan View Post
    "A happy wife makes for a happy life." ... (However, I would not put too much faith in them.)
    I've believed for 25 years.
    She once asked me put this style on her car. The instructions said to take them off before using an automated car wash.
    Just to be clear, I believe the link to be true and won't have them on my car. She wants advice on where to put them on her car. I don't have much confidence anywhere underneath. I thought about behind the grille. There's no airflow there and the sound wouldn't get out. But they're ineffective anyway.
    I shouldn't say that. They help give me a happy life!
  16. Remove Advertisements
