05 STS with 4.6. P0174 Lean bank 2 Fixed
Results 1 to 6 of 6
Cadillac STS Forum - 2005 through 2012 Discussion, 05 STS with 4.6. P0174 Lean bank 2 Fixed in Past Cadillac Vehicle Discussion; Just thought I would post this fix incase others are having similar problems. My car has around 90k on it ...
    nwjones18 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS V8
    Feb 2013
    Georgia
    30
    205
    Just thought I would post this fix incase others are having similar problems. My car has around 90k on it and a couple days ago I got a CEL. I went looking for vacuum leaks since that's the easiest thing to cause a lean code. I found that the rubber ends on the vacuum pipe that goes from the passenger side valve cover to the rear of the intake manifold were totally disintegrated. the Pipe is 3/8 and I had some fuel line laying around so I just cut a piece for either end and replaced it. Getting the hose off the back of the intake is a challenge but doable. Hope this helps someone, I have to figure that everyone with the N* will run into this at some point.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,574
    Re: 05 STS with 4.6. P0174 Lean bank 2 Fixed
    PCV dirty air line connector breaks are common across the Northstar line. If necessary, that entire line can be replaced with a length of proper ID fuel line - fuel line has a reinforcing braid molded in.
    Any of the other preformed plastic vacuum pipes and connectors may be replaced with lengths of proper ID vacuum hose from the Help! racks at parts stores.
    Thanks for the feedback. P 017X codes are usually vacuum leaks - they show up as "lean mixture codes".
    achavez's Avatar
    achavez is offline Cadillac Owners Member
    Automobile(s): 2005 STS 4.6ltr 1SE
    Aug 2013
    California
    31
    34
    Thanks for the input. These engine bays run extremely hot. Hotter than my turboed 4cyl awd sedan I had. Thats very harsh on the lines, wires, connectors
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Lean can also mean loose intake bolts; lkewise mileage appropriate. In my car, it took about 20 ignition cycles for it to clear after I reattached a hose & tightened bolts.
    Today, a month later, passed WI OBD emission test w/o ever having the code reset.
    Feb 2013
    Georgia
    30
    205
    Quote Originally Posted by EChas3 View Post
    I preemptively tightened the intake bolts when i first got the car. They were all quite loose. I just cleared my codes with a scanner.
    Thanks though!
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    How long ago? Did you torque them?
    I recall one member reported that after the previous owner had overtightened his, they wouldn't hold and I think he ended up replacing the gasket.
  9. Remove Advertisements
