Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: Help with 2005 sts radio
    Sep 2013
    31
    1
    I have a base v6 sts with a non nav radio I would like to know if I can upgrade that radio for the factory sts indash unit and if not can I upgrade to an aftermarket indash DVD keeping all my features and settings?
    mjcaddy's Avatar
    mjcaddy is offline Cadillac Owners Fanatic
    Automobile(s): 09 1SG STS4 & Subie CrossTrek (retired 03 DeVille & 05 V6 SRX4)
    Oct 2010
    Chicagoland
    32
    428
    Re: Help with 2005 sts radio
    by my understanding the STS nav convert is just plug and play, the nav and the base radio both uses the same connectors in the back the only thing i'm not sure about is the VSS (vehicle speed sensor) you'll need to get that data to the navigation to be able use some of the functions otherwise the car will think it's driving all the time.
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,549
    there is a huge long thread about this...
    http://www.cadillacforums.com/forums...sts-100-a.html
    ALL YOU HAVE TO DO TO INSTALL NAV INTO A NON NAV STS IS:
    Take your stock radio out.
    Unplug the two harnesses and the am/fm antenna.
    Plug the two harnesses into the nav.
    Plug the antenna into the top am/fm antenna connector.
    Pop the dash panel by the windshield up and run the GPS antenna connector through to the NAV/radio location.
    Plug (or splice) the GPS antenna into the pink connector on the back of the NAV.
    Reinstall the NAV.
    Although to get full functionality there are more steps needed than that.
  5. #4
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    I think there's some posts that make the VSS connection sound harder than it really is. The members here are great and running a wire isn't that big a deal for many of us. I think it's the steep climb to get turn-by-turn guidance audio and install the additional speakers & different/additional amplifier that are required to get the benefit of the Bose 5.1 that convinced some members to go aftermarket.
    After all, unless you're going to add ACC & HUD integration, the STS Nav isn't at all remarkable. There are some nice posts showing aftermarket refits that look nice and bring more state-of-the-art Nav & connectivity options.
  6. #5
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Quote Originally Posted by EChas3
    Problem going aftermarket for some is the loss of switch on the fly adjustment of the magnetic ride control and adjusting the driver 1/2 personalization settings.
  7. #6
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,061
    I know plenty of 1st Gen CTS folks who have installed aftermarket HUs and retained DIC functionality. However, I have not seen it done in an STS on here yet. In the CTS the disc changer mechanism is removed from the unit and the new HU installed in its place. The motherboard needs to be modified and a few circuts need to be rearranged in order to keep the DIC working but its been done. Can't imagine it being much different in an STS as the non-NAV units are fairly similar.
  8. #7
    mjcaddy's Avatar
    Oct 2010
    Chicagoland
    32
    428
    It's different, the first gen CTS, 04-06 SRX have the DIC in the radio/nav, so they need to keep the opt part and modify the board to keep the DIC.
    STS should be easier since the DIC is in the dash, but as 1badcadsts said they gonna lose the MRC and the driver personalization settings.
  9. #8
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,061
    Quote Originally Posted by mjcaddy View Post
    Couldn't the board in the STS radio be modified to retain MRC and memory function?
  10. #9
    mjcaddy's Avatar
    Oct 2010
    Chicagoland
    32
    428
    You probably don't need to modify the board since you are changing the whole unit but you'll need a programmable unit to add that function to it, If that's available then it's matter of getting the "function" that being used by the oem unit and program it in the new unit.
  11. #10
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,061
    I'm not saying to remove the entire unit, what I'm saying is to do the same thing the 1st Gen CTS owners do, remove the CD mech and put the new HU in place of it, leaving the OEM display there as well as all factory buttons. The new HU is installed inside the body of the OEM unit.
  12. #11
    mjcaddy's Avatar
    Oct 2010
    Chicagoland
    32
    428
    that will work, the only thing is :
    https://www.dropbox.com/s/1szjysds3h3ho69/2.JPG
    If you "cut out" the CD changer :
    https://www.dropbox.com/s/lkpf0pgqbsncqdd/1.JPG
    you'll lose the buttons on the front too,
    vs:
    https://www.dropbox.com/s/0k6qo7tzwnoc533/cts1.JPG
    If you are talking about the base radio (non NAV) then yeah it should work the same way in the CTS, but in the base STS I dont think there is MRC.
    https://www.dropbox.com/s/bp38chbtva...ts%20radio.JPG
    if you think the other way around, keep the bottom part (nav units), move whatever you need from the upper part (board, connections, etc), then remove the screen and install your new unit there,
    I'm sure there are units that can still function as a screen, so you'll still have all your functions plus the new unit functions,
    all that is just in theory,
    I have new project (work) is coming soon, if that works out, then i'll have the money and the time to do this.
  13. #12
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Quote Originally Posted by 1BadCadSTS View Post
    I agree on the MRC but the old radio could be reconnected to save setting changes when needed. I read somewhere about a vendor making a module that helps with chimes. The best aftermarket job I saw on this forum had the base radio still installed.
    I don't think I'd do it. I like the OEM but IF.....
  14. #13
    ITSQUIK's Avatar
    ITSQUIK is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS
    Jul 2010
    314
    I relocated my factory unit to the trunk.
    [IMG][/IMG]
  15. #14
    Hhunter is offline Cadillac Owners Member
    Automobile(s): 2005 STS V8
    Oct 2013
    29
    19
    Why is it in your trunk?
  16. #15
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,061
    That keeps the car's data bus intact and allows him to just piggy back an aftermarket unit without interfering with anything stock.
  • You may not post replies
