Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 32
Thread: Park Assist Down
  1. #16
    May 2010
    460
    Re: Park Assist Down
    Got it! I see it now! I thought that it might be somewhere else. Once I saw "Collision Avoidance" I automatically thought it was referring to the HUD collision avoidance and stopped reading the rest of the description !!
    Thanks for the directions on alldatadiy and the tip about alldatadiy. Got 3 years for $20. I think it will be well worth the money! Now to get to work on it .
  2. #17
    May 2010
    460
    Found the module in the trunk. The toughest thing was getting in and out of the trunk...YIKES! I almost couldn't get out. Thought I was going to have to call for assistance!!
  3. #18
    zlgibby is offline Cadillac Owners Member
    Automobile(s): 01 Eldorado ETC
    Oct 2012
    Minnesota
    40
    Well I found mine too and well your roght about the trunk and getting stuck im in there now lol but the hardest thing was getting the 2 kickers out the box is as big as the trunk lol.
    Anyways I found the diagnostic port I believe how do I figure out if its dead, again I have no light or sound anymore coming from the little black screen.
  4. #19
    May 2010
    460
    Your right about that! I tested mine today and got no response at all. Went right to my computer and ordered a new module.
  5. #20
    Oct 2012
    Minnesota
    40
    Hey Neutrocuted could I possibly get a website and part number from where you order it from. cant seem to find it anywhere.
  6. #21
    May 2010
    460
    I'll PM you the info! Search for "GM Parts" and you'll get a bunch of 'em.
  7. #22
    Oct 2012
    Minnesota
    40
    Thank found it let us know if the module worked for you
  8. #23
    May 2010
    460
    I received my new module yesterday, I popped it in and now it works like it should! Now to see if I can put all the trunk panels back in without breaking something. I think I destroyed the 4 plastic clips that hold up the ceiling during removal so I might have to go pick up a few of those. But I want to make sure I get the "easy to use/remove" replacements because I believe I need a new RIM module.
    The problem I'm having with it is my outside trunk button no longer works. The trunk will open with the remote and with the inside button, but not the outside one. It also began to slowly fail, first becoming occasionally intermittent, then worse and worse until it wouldn't work at all. Tried replacing the button to no avail and after reading up on the trio of modules in the trunk I think it's the RIM.
    But that's another story that's going off subject and that can wait. At least I canget into the trunk!
    Thanks to all you guys that assisted me! I know I wouldn't have been able to get it done without your help.
  9. #24
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Called it
  10. #25
    May 2010
    460
    Yeah ya did!
    Quote Originally Posted by 1BadCadSTS View Post
    Called it
    What cha got on the RIM?
  11. #26
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    What do you need to know about the rear integration module?
  12. #27
    May 2010
    460
    Any tests that can be performed on the outside trunk switch?
  13. #28
    Ludacrisvp's Avatar
    Ludacrisvp is online now Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,549
    I bet it has nothing to do with the RIM and is likely just the antenna for the trunk release has failed.
  14. #29
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    The antenna for the trunk release is the antenna for the rcdlr. If your fob works when pressing buttons on it rather than using the proximity then its not bad. You likely have a failed trunk release button.
  15. #30
    May 2010
    460
    As I mentioned I did replace the button, the remote works, and the inside button works.
  • You may not post replies
