2008 STS Blown rear end, Brake lines rusted out
Page 1 of 2 12 LastLast
Results 1 to 15 of 30
Cadillac STS Forum - 2005 through 2012 Discussion, 2008 STS Blown rear end, Brake lines rusted out in Past Cadillac Vehicle Discussion; Hello, I have a 2008 STS rwd, v6. It was my new car dec 24th of 2012 with under 18,000 ...
    Erand is offline Cadillac Owners Member
    Automobile(s): 2008 sts
    Sep 2013
    Ohio
    11
    Hello, I have a 2008 STS rwd, v6. It was my new car dec 24th of 2012 with under 18,000 miles, now has around 26,000. I had the car out the other weekend, no noise, no clunks, parked back inside only to come out to a puddle of oil under the rear end couple of days later. After further inspection, something let loose and put a hole in the bottom of the casting from the inside out. I don't seem to find anyone else that has had problems like this anywhere. While I was down there, my brake lines were so rusted there was tiny bubbles coming out all over them! On an 08 with 18,000 miles?!! Currently in a battle with dealership over rear end, which should be covered under my platinum extended warranty plan, and getting brake lines replaced under the corrosion plan from gm. ( dealer said it was surface rust) Anyone else run into any problems like I am having with what I thought was the best car I have ever owned???
    dannyquest is offline Cadillac Owners Fanatic
    Mar 2012
    columbus ohio
    382
    Re: 2008 STS Blown rear end, Brake lines rusted out
    Erand, The answer is no on my 06 STS. Sound as if you have a bad brake line that was not coated very well from the factory. Has this car been garaged and not park out side. I see that you are also from Ohio, Maybe the last time the car was driven it was in snow & salt and not soon wash off. Danny
    Sep 2013
    Ohio
    11
    Yes it has been kept clean since I have had it, and parked inside. With only 17,750 miles in Dec, I can't imagine it has seen much winter driving. The rest of the car is perfect, not a spot of rust ANYWHERE on the outside. although the brake lines look like they have been in the salt mines last 5 years. I have a 2004 Jeep that I drive all winter for last 6 winters, never undercoated, or washed, 140,000 miles now, and it looks better then the sts underneath.
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,722
    Quote Originally Posted by Erand View Post
    Hello Erand,
    I am sorry you are experiencing a concern with your brake lines being rusted out and the issue with the dealer you are working with. I would like the opportunity to further discuss your situation with you. Please reach out via private message and include your contact information, VIN and dealer name and location. I look forward to hearing from you.
    Sincerely,
    Laura M.
    Cadillac Customer Care
    BarrySTS is offline Cadillac Owners Member
    Automobile(s): 2008 STS NS
    Jan 2010
    42
    Any chance this car came from the east coast, where it may have sat in a flood, up to it's floor pan in salt water ? Might explain the short life of the rear end.
    Sep 2013
    Ohio
    11
    Hard to say. If it was in a flood, should of been reported, but I do believe it was always a local car.
    KRSTS Guest
    My 08 has 58K miles and I've had it since Mar 2008. I have none of the issues you have described. Sounds like it may have been abused in its former life. I like BarrySTS's theory.
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    GM knows where it was sold. Ask Customer Service to run a full service history against that possibility. Your claim would be aginst that seller; but you may have a valid claim.
    Even a drive through deep salt water (covering the vent) can ruin a diff. Don't you know why you should never drive into water of unknown own depth? Diff's are expensive!
    Sep 2013
    Ohio
    11
    caddy2.jpg So here is the brake lines I was told were surface rust. Now, GM owners is sending a specialist to look at my car to see if it will be covered under their corrosion plan.
    Mar 2010
    Detroit, USA
    12,722
    Hello Erand,
    That seems like quite a bit of rust! Thanks for keeping us updated, and please continue to do so. If you would like Laura or I to contact the dealership on your behalf, please feel free to let us know via private message. Thank you very much for your time.
    Gregory W.
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    If it's rusted more than halfway through, that couldn't be termed 'surface rust' could it?
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    Yeah but the rust warranty is "rust through" I believe.
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    I advocate pleasant persistence. But get those fixed before they kill someone.
  16. #14
    btlegacy is offline Cadillac Owners Member
    Automobile(s): 2005 STS V6 RWD
    Mar 2013
    NC
    31
    70
    That seems to be quite a bit of rust and not something I would consider just surface rust. Just keep pushing and make them replace it.
  17. #15
    Sep 2013
    Ohio
    11
    I would say when fluid is leaking out, it would be a through hole, maybe small, but still there...... Won't know any more for a few days when the district gm guy checks it out or at least calls. How about the rear end, I understand its a 3rd party warranty, but was sold by a Cadillac dealer, on a Cadillac. Platinum!! Best you could buy I was told. Now that I have a problem, they don't want to cover it due to scratches on the bottom of the body. Dealer told me, that I must of had my car stuck on a curb and was rocking it to get off, causing damage to the part.... what a load of bs! Car was NEVER abused in my hands, how can they say it was??? Most folks don't by a caddy to take it 'off roading' that I know of.
  18. Remove Advertisements
