No Fobs detected
Results 1 to 6 of 6
Cadillac STS Forum - 2005 through 2012 Discussion, No Fobs detected in Past Cadillac Vehicle Discussion; I have a 2005 STS Cadillac,when I press the start button, a message appears on the DIC "No Fobs detected"when ...
    ylarika27 is offline Cadillac Owners Member
    Automobile(s): STS
    Sep 2013
    1
    No Fobs detected
    I have a 2005 STS Cadillac,when I press the start button, a message appears on the DIC "No Fobs detected"when I insert the Fob into the emergency access slot in center console then I can start my car,can somebody help me to salve this problem?
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    Re: No Fobs detected
    Try changing the battery.
    If you have a 2nd fob you can test it out by putting that battery in your primary one. I wouldn't do it though because the less times you have to open and close these things the less likely they are to break. If it still doesn't work with the new battery make sure it isn't upside down.
    flittlejr is offline Cadillac Owners Member
    Automobile(s): XLR
    Nov 2008
    Virginia Beach
    73
    20
    I have same problem. Both batteries are new as of Sept. No FOBS detected on screen, but when placed in console holder works fine. Got home everything is normal. I know that nothing fixes itself so should I 1. reprogram fobs (both showing correct driver etc after using console holder. Wait for it to happen again and replace RCDLR?
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,044
    Also make sure the fob is NOT near a cell phone when in your pocket. I've had my door not open a few times only to find out that if I separated the two the door opened just fine, the cell phone was blocking the signal.
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    High RFID interference will cause an issue. Theres also a TSB on NO FOBS DETECTED issue. Ill see if I can dig that up later.
    Edit
    Never-mind found it in PDF
    http://www.cadillacfaq.com/stsfaq/ts...-08-52-008.pdf
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,687
    Hi ylarika27,
    I see your post was a few months back, but I wanted to check in and see if your concern has been resolved. If not, please feel free to send us a private message with further information. Thank you!
    Jessica (assisting Laura)
    Cadillac Customer Care
    Quote Originally Posted by ylarika27 View Post
    Hello flittlejr,
    Please let us know if you would like us to assist further! We would be happy to speak with your dealership for further technical advice.
    Quote Originally Posted by flittlejr View Post
  9. Remove Advertisements
