Oil valve
Results 1 to 3 of 3
Cadillac STS Forum - 2005 through 2012 Discussion, Oil valve in Past Cadillac Vehicle Discussion; I am trying to change out the oil pressure valve located inside the base of the oil filter housing. The ...
    fla48 is offline Cadillac Owners Member
    Automobile(s): 05 sts
    Aug 2013
    1
    Oil valve
    I am trying to change out the oil pressure valve located inside the base of the oil filter housing. The part number is 2501-4612, title on the part box reads "valve oil flt". I cannot remove the old valve. Is there a special tool or procedure used for removal of this part.
    Thanks
    btlegacy is offline Cadillac Owners Member
    Automobile(s): 2005 STS V6 RWD
    Mar 2013
    NC
    31
    70
    1harleyman is offline Cadillac Owners Member
    Automobile(s): '98 sts / '06 sts
    Jul 2012
    ohio
    56
    50
    Re: Oil valve
    I changed mine 6 months ago, if i remember it just takes a deep well 6 point socket , nothing special but it was very tight, it took a half in drive ratchet. Dont over tighten when installing the
    new one
