So anyone have $2600 to burn???
Page 1 of 2 12 LastLast
Results 1 to 15 of 23
Like Tree6Likes
Cadillac STS Forum - 2005 through 2012 Discussion, So anyone have $2600 to burn??? in Past Cadillac Vehicle Discussion; Found these on aliexpress today ... $1300 each. Left SLS headlight Right SLS headlight...
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,539
    Left SLS headlight
    Right SLS headlight
    PontiacV8 and mjcaddy like this.
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    Re: So anyone have $2600 to burn???
    Wow impressive. In my opinion you'd have to go all in and do the drl/foglight swap too. If only those were sae 100 lights. If only.
    Ludacrisvp likes this.
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,539
    The DRL / Foglight swap would also require a new front bumper as the cutouts are different.
    It would be a sweet setup for sure, but even more cost prohibitive...
    We can only wish for things like the SAE 100 headlights...
    Feb 2013
    Whitestone, NY
    28
    3,211
    Forgot about the different bumper cutouts. These have the same look of the cts ones. Drl on top and projector on bottom.
    PontiacV8's Avatar
    PontiacV8 is offline Cadillac Owners Fanatic
    Automobile(s): 2015 Camaro 2SS, Sold: 2006 STS (EXP) 1997 Seville STS (EXP)
    Dec 2006
    Germany / Nordhorn
    423
    ...the clear section above the "single" bi-xenon AFL lens is the LED "parking light"... ...but yes...they almost look like the newer CTS lights...
    ...but it's not only the $2600 for the headlights...there are some more "costs"...and some work to do...
    ...you also need the headlight control module...and a complete -or at least a part of the- SLS front/lamp wiring harness to connect and control the lights...
    ...Alex ("targetSTS" ) told me, these 2010-up model year uplevel Cadillac SLS lamps use a complete other wiring and "connection system"...the harness and connectors are different to "our" cars...(...e.g. feeding/controlling the auto-leveling and the left-right motors inside the headlights...) ...you have to splice it in into the original harness...
    ...the headlights/housings themself fit perfectly...same form and all tabs are in the same position as "stock"...
    (...the 2010-up model year entry level SLS (and all 2007 - 2009 SLS) still got the same "old" dual lens headlights (with HIDs for driving light) and wiring the european/ECC specs export STS has...)
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    I still like out dual headlamps. More light output with an HID headlight bulb and a halogen HID bulb then a BI-Xenon set up.
    The only reason Id consider the upgrade would be if they had integrated light pipes like the newer ATS and XTS. Without that this is just another way to make an STS look like a CTS and I am not a fan of that.
    Feb 2013
    Whitestone, NY
    28
    3,211
    I agree that the stacked dual projectors are nice but auto leveling and swiveling headlamps would be nice.
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,539
    Quote Originally Posted by PontiacV8 View Post
    Sounds like you have your work cut out for you a little bit.
    If any forum member gets more SLS equipment my money would be on you getting it done.
    Sure would be nice to see them lighted up and to see what kind of output they have.
    I wonder if the projector cutoff is the DOT or ECE cutoff...
    targetSTS is offline Cadillac Owners Fanatic
    Automobile(s): 2005 cadillac STS AWD 1SG
    Mar 2011
    34
    392
    patience guys, I'm working on it )))
    PontiacV8 and Ludacrisvp like this.
    PontiacV8's Avatar
    Dec 2006
    Germany / Nordhorn
    423
    Quote Originally Posted by targetSTS View Post
    ....yeah....
    Quote Originally Posted by Ludacrisvp View Post
    ...the headlights got a ECE label/E-sign, so it should be ECE cutoff...
    ...here a detailed image..."E9" in a circle on the glass:
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,539
    good to know... Keep working on it.
    I'm sure you'll be able to talk PontiacV8 into picking up a set of them.
    Ah indeed it does have E9 listed there.
    Out of curiosity did the export STS lamps get the ECE cutoff too? (I assume it did but one never really knows what to expect from GM)
    Sent from AutoGuide.com Free App
    PontiacV8's Avatar
    Dec 2006
    Germany / Nordhorn
    423
    ......time will tell...
    ...yes...they are ECE approved (mine are E13, and I saw late ones with E9)...and they do...
    Charles Warren's Avatar
    Charles Warren is offline Cadillac Owners Fanatic
    Automobile(s): 2008 sts-v black raven 2004 cts black raven
    Nov 2011
    Atlanta, Georgia, United State
    88
    459
    Nice. Sae100 can be rigged lol get escalade leds and goto work. I'm doing a retro on my fogs bow. Only reason is because the guy that painted my car broke my fog projectors. How I dunno but they are made of glass (bowl is glass smh). But back on tooic I think it would look a tad different than cts. I like em but not $2600 not that much liking lol
  16. #14
    Feb 2013
    Whitestone, NY
    28
    3,211
    Interesting how Cadillacs have the projector reflect blue. You see it when the light is off. Not all automakers do blue. Most don't. But these particular lights don't seem to reflect blue on the projector.
  17. #15
    Nov 2011
    88
    459
    valeo is the company that made our projectors. not all of them do it xlr doesnt cts doesnt either
  18. Remove Advertisements
