Front brake rotor suggestions?
Results 1 to 6 of 6
Cadillac STS Forum - 2005 through 2012 Discussion, Front brake rotor suggestions? in Past Cadillac Vehicle Discussion; I have the SF1/JE5 package combo, and the front rotors are warped enough I notice at very low speed. I ...
    mckellyb is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 STS N*, 1SF, 144K mi.
    Apr 2011
    Fort Worth
    650
    I can't help it, it bugs me.
    Is there a consensus on the best replacement rotors for this rather dense automobile? While I'd like to go slotted/drilled, I've had rather questionable luck with drilled in the past, and that's more material removed which could be soaking up brake heat.
    While I'd like to say "cost is no object", it kinda is. I'm not shooting for bottom-of-the-barrel, but at the same time, I don't want to drop $500 on a pair of discs.
    Thanks!
    shameless madtuner plug: I LOVE how my transmission does pretty much what I tell it to, now. you want 5th gear @ 28 MPH? Done.
    Stay in 5th until you're at about 90% throttle? Yep, it'll do that, too, if you tell it.
    And crisp shifts! LIKE THEY SHOULD BE!!!!!
    I don't want some slurred 1 second shift. I want BAM, next gear, done.
    C&C's Avatar
    C&C
    C&C is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac XT5 (2017)
    Feb 2008
    Mount Pleasant, SC
    66
    1,921
    Re: Front brake rotor suggestions?
    Sometimes your brake pads/rotor can get some glaze on them. I would try a couple aggressive stops (safe place of course) and see if you pulsating brakes resolve themselves. Actual brake rotor warping is a lot less common then complainants realize.
    sub613's Avatar
    sub613 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 STS 1SF N* RWD NAV F55
    Mar 2009
    NC for Now, Florida SOON
    704
    LightbulbRe: Front brake rotor suggestions?
    I recommend Slotted, NOT DRILLED, rotors.
    This way, you have the wiping action without the loss of mass.
    Drilled rotors are recommended in extreme conditions.
    Daily drivers may not need this technology.
    Its NOT the question of soaking up heat,
    but, dissipating the heat !
    Happy Motoring.
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,494
    I went here:
    http://brakeperformance.com/brake-ro...ake-Rotors.php
    I went with slotted and drilled on all 4.
    They offer slotted and dimpled as well as slotted only or drilled only or plain.
    Free shipping, also try this coupon code of DISC13
    Front pair of rotors would run you between $104 and $205 depending on what you choose/need.
    If you get the dimpled and slotted you get free pads for that $205 price.
    BlueAngel#07's Avatar
    BlueAngel#07 is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 DTS PERFORMANCE
    Feb 2013
    Minnesota
    1,048
    SP PERFORMANCE. has drilled and slotted or dimpled rotors plain and zinc coated. Lifetime warranty against cracking, zinc coated really look nice and won't rust if I recall.
    Apr 2011
    Fort Worth
    650
    Yeah, this isn't glazed, it's slight warping.
  9. Remove Advertisements
