2008 Rear back-up Camera
Page 1 of 3 123 LastLast
Results 1 to 15 of 38
Like Tree2Likes
Cadillac STS Forum - 2005 through 2012 Discussion, 2008 Rear back-up Camera in Past Cadillac Vehicle Discussion; I just purchased a 2008 STS and it has a back-up camera on the license plate frame. Can anyone tell ...
    soyk.24 is offline Cadillac Owners Member
    Automobile(s): 2008 STS
    Aug 2013
    33
    34
    I just purchased a 2008 STS and it has a back-up camera on the license plate frame. Can anyone tell me if this was an option from the factory or if it would have to have been an add on aftermarket? It is not disguised very well, it is a pretty noticeable camera that bolts in the same holes with the license plate. The screen shows up on the rear view mirror. Just curious if it is factory installed or not. Thank you.
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    Re: 2008 Rear back-up Camera
    Aftermarket. Sts never got the backup cam all the way through the last sts that rolled off the line.
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,536
    if the OEM mirror was replaced you likely lost the intellibeam highbeams (if the highbeams even work without it).
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Quote Originally Posted by Ludacrisvp
    If he has hids
    sub613's Avatar
    sub613 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 STS 1SF N* RWD NAV F55
    Mar 2009
    NC for Now, Florida SOON
    704
    CoolRe: 2008 Rear back-up Camera
    soyk.24
    Could you post a pic of your Rear View mirror ?
    Thanks,
    Happy Motoring
    Aug 2013
    33
    34
    Thanks for the responses so far. My main reason for asking this question is because since i purchased the car used a few weeks ago, the High Beams do not work. I called the dealer and they are of no help unless i bring the car in and i will have to pay for any labor and parts since it was not certified. The car only has 52,00 miles on it, so i am pretty sure the high beam bulbs are not burnt out. i have attached a few pics of the rear view mirror with the back up monitor on, a view of the back of the mirror, and also some pictures of the back up camera itself. I read that you can turn the intellibeams off by pushing the power button on the mirror. When i do this, the back-up camera does not work then either. Any more help on this issue would be great. I have no issue at all getting rid of the back-up camera, it is pretty much useless anyhow.20130821_203955.jpg20130821_203848.jpg20130821_203837.jpg20130821_203741.jpg
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    You have your Damn Previous Owner (DPO) to thank for substituting your original mirror with the aftermarket mirror/camera setup like suggested. Your car probably was built with the TQ5 Intellibeam option which has a sensor in the mirror to automatically dim the headlights. Without that mirror, your high beams won't work. You can check the label on the spare tire cover to be sure.
    You might be able to find the right mirror through an auto-recycler. If you decide to go new, check with Chris Heath at Rippy's Cadillac (on this forum). He is very helpful and competitivly priced.
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Op where are you located?!
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,536
    If you have HIDs then you have intellibeam which is why the high beams don't work. You might find a dealer that will reflash the car to delete the option from the car, not sure if that would allow the high beams to work as there is likely a different setup of relays and wiring in the car.
    Basically trash that mirror (sell on eBay) and get the correct intellibeam mirror from Rippy.
    Sent from AutoGuide.com Free App
    Aug 2013
    33
    34
    I am in Wisconsin. How hard is it to replace the mirror? What do i do with the back-up camera and wiring for it? Does anyone have a picture or part number for the correct mirror at all? I figured it had to be something with that camera. I talked to the dealer and had them ask the previous owner if they had any issues with the high beams at all and they told him they did not recall any issues. BS. It was a one owner car by an older couple. I think they are just losing their memories!
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Give any Cadillac dealer your VIN and they can price the correct mirror for you; as can any of the regular sources, perhaps even Rock Auto.
    PontiacV8's Avatar
    PontiacV8 is offline Cadillac Owners Fanatic
    Automobile(s): 2015 Camaro 2SS, Sold: 2006 STS (EXP) 1997 Seville STS (EXP)
    Dec 2006
    Germany / Nordhorn
    423
    Quote Originally Posted by Ludacrisvp View Post
    ...hmm, yes...should work...somehow I think (maybe a programming/reflash via Tech II or something like that) ...cause...as an example:
    ...you know, all european export STS got HID's (V6 and V8 )....but Intellibeam wasn't available...!(...and our high beams work... )
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,536
    Quote Originally Posted by soyk.24 View Post
  16. #14
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    I'd be interested in the mirror you have now.
    Does or did your car have lane departure? If so that may be a different mirror than others.
  17. #15
    Aug 2013
    33
    34
    I do not believe it has the lane departure feature at all. Once I get this all figured out and get the correct mirror ill let you know.
  18. Remove Advertisements
