Front wheel bearing
Results 1 to 4 of 4
Cadillac STS Forum - 2005 through 2012 Discussion, Front wheel bearing in Past Cadillac Vehicle Discussion; Can anyone help me with the torque spec for a front bearing nut on a 2009 STS-AWD? I'm going to ...
    Mark55 is offline Cadillac Owners Member
    Automobile(s): 2009sts
    Aug 2013
    61
    1
    Front wheel bearing
    I'm going to attempt to replace the front wheel bearing because the traction control light comes on intermittently and when I plugged in, the "sensor failure" response comes up.
    Anyone ever have this issue?
    Thanks
    Mark
    TheCadillacKid's Avatar
    TheCadillacKid is offline Cadillac Owners Member
    Automobile(s): 2009 STS4, 1979, Coupe deVille, 2000 Camaro Z28 M6
    Mar 2006
    Brooklyn, New York
    29
    Re: Front wheel bearing
    Do you have access to a scanning to check the speed of the sensor that's in question? Look for no speed while driving or erratic changes in value
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    You're certain it's not the sensor? I believe the bearings are replaced as part of an assembly.
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,536
    Notice:
    Avoid tool contact to the outer constant velocity boot seal when removing the wheel bearing mounting bolts.
    Failure to observe this notice may result in damage to the CV boot.
    Install the wheel bearing/hub mounting bolts.
    Tighten the wheel bearing/hub mounting bolts to 135 N.m (100 lb ft).
    Install a new wheel driveshaft retaining nut.
    Tighten the nut to 160 N.m (118 lb ft).
  7. Remove Advertisements
